i wouldnt call it bad effect...the worst just your speedo will be under reading like speedo shows 110km/h meanwhile actual speed just around 100km/h which is good to avoid speed trapHi Sifu's,
would like to check, i'm thinking to change my tyre size from 215/50R17 to 215/45R17, but according to the recommended size change, the new size would be more than >3% difference, so will there be any bad effect except for like speedo inaccurancy?
215/45R17 is much easier to find and cheaper by a lot...so thinking to change to this size only if its recommended..
if want it to be closer to 3% rules, u need to increase the width... 235/45-17 will be the closest to stock tyre...but rim width might be an issue (need atleast 7.5" wide rim of best 8" wide rim)
i would suggest 225/45-17..it will be compromise between tyre width and overall diameter compared to stock tyre size....
