Change of tyre size
7,514
Hi Sifu's,
would like to check, i'm thinking to change my tyre size from 215/50R17 to 215/45R17, but according to the recommended size change, the new size would be more than >3% difference, so will there be any bad effect except for like speedo inaccurancy?
215/45R17 is much easier to find and cheaper by a lot...so thinking to change to this size only if its recommended..
i wouldnt call it bad effect...the worst just your speedo will be under reading like speedo shows 110km/h meanwhile actual speed just around 100km/h which is good to avoid speed trap
if want it to be closer to 3% rules, u need to increase the width... 235/45-17 will be the closest to stock tyre...but rim width might be an issue (need atleast 7.5" wide rim of best 8" wide rim)
i would suggest 225/45-17..it will be compromise between tyre width and overall diameter compared to stock tyre size....
Zeroshift
133
13
3,018
In the end i just change back to the same 215/50/17. Since the price is similar with 225/45/17...
---------- Post added at 02:15 PM ---------- 6 hour anti-bump limit - Previous post was at 02:15 PM ----------
Thanks for the feedback bro..
30,002
Some sizes not meant to be changed. Either becomes too low or the rims not wide enough. Another size is like 185/55 R16. Change to 195/50R16 too small, 195/55R16 too big, 205/50R16 diameter ok, but original rims too narrow.....:banghead:
Zeroshift
133
13
3,018
Ya..that why change back the same size..looks weird when change to smaller size...
7,514
aftermarket wheel with 8jj/9jj sure solve the problem :biggrin:
30,002
Haha...i really don't know how those stance cars driver drive their cars man...The car is so low and their ride is rock hard...
Really salute them...:adore::adore:
Follow one that day, he was quite fast on flat road, then when approach a bump, he comes to almost dead stop then drives at 45 degree angle over the bump.....hhahahhahah
A Post Every 5 Mins
sifus... what paint should i use , insted of spray, coz spray wont last long . so i was thinking of getting those gate /fence paint izit ok..or is there paint special for brake calipers.? thanks
