Sorry for saying this but this is what I want to say....why need to change the engine? It's not like the CPS engine is so lousy. It has less power compare to a TC engine....of course la..1.6 NA only....what do you expect. A 200hp 1.6 NA? but always break down...you want?
I see now a lot of people before getting use to a car's handling already say want to BOT want to change engine.....in the end lost control because not familiar with the car's handling and limits. For what I say? I also like the surge of TC but I love the linear power of NA and the responsiveness nature. The CPS engine got potential one, just depends whether the owner knowledge on cars, engines, mechanical skill deep or not only. I suggest the TS to really go and understand the engine 1st and it's behavior...Then get used to it and mod along the path. Swapping out the engine is just a shortcut way of gaining more power....if you go every sweat and blood to build every drop of HP from the CPS engine....you gain more knowledge and respect....
Also, I know some lazy people who swap engine will just go to a few chop shop look for engine, test test the engine then see ok then buy, transplant into the car do some oil change and some parts change then drive and mod and up boost....then boost here boost there in the end engine kaput after 5 to 6 months....Then phone me, Joe my engine blow already, Joe my engine turbo kong, Joe my gearbox die already, Joe my ball shrink already because crankshaft patah....then with all the sad emoticons...
If TS really going to transplant, I suggest you after getting a half cut engine. Strip the whole engine down to bare then rebuild everything from scratch including the gearbox. Change every possible parts to new....then only put into the car.....this is what I consider a neat and correct way to do it. If not you are just putting a used engine (which you don't know how it was driven or care) into your car....
TS, I'm not sure what driving experience just a piece of advice. Enjoy the Neo, start doing up the handling department 1st. Power should be the last thing in your mind (although some light mods can be done like intake and exhaust). Master the handling department 1st. Although your Neo might not have 200hp or 180hp but if your car's handling is setup superbly it will still be very fast around the corners. Power is nothing without handling...
Cheers...just my noob comment
