car vibrating when idle
drill
617
12
5,018
Damansara
hi all,
i hv a kancil with ejde auto engine (similar engine to kelisa)...
the problem is, when i put into D or R and puts on the brake, it will shake the whole car.
i've noticed that this occur when the rpm is less then 1800, this problem will occur.
all engine mounting has been changed and firing on each plugs are ok.
Any suggestion what else to check?
tried to increse the idle timing to 2k rpm, then its ok. but i think its not normal to idle at 2k.
also i've noticed that if let say on a Neutral gear position, if the idle has been set to 2k rpm, once i
put into D or R, the timing will drop to around 1.3K. Please help.
drill
617
12
5,018
Damansara
Oh yaa. Forgot to mention ive done that too.
drill
617
12
5,018
Damansara
errr okie... but where is it located?? or do u mean the screw thingy that we use to adjust the timing?
drill
617
12
5,018
Damansara
i think after market... but i've hardened it with silicone paste. the black one... btw... case on hold... since the car has been 50% sold.
Just last month, we were given an exclusive opportunity to drive up the Genting hills with Jean Alesi in a loaner Exige S provided by Lotus Cars Malaysia. To put into perspective: Up close and personal with F1 legend, Jean Alesi and an Exige S for 4 days. It was Jean's last day in Malaysia before his return to Geneva. I thought that'd be the best time of my life, yet. I was wrong.
We received an invite...
