car vibrating like crazy!!!! urgent advise
hamtaro00
279
39
528
Ipoh
hi guys.need your opinion n advise.my perdana with 6a12tt manual had this very funny prob.
i had changed 4 recon drive shaft n a new 1 but car still vibrating.worst is new DS.i thought it can solve d problrm but even worst. 90kmh already start very bad vibration. all mounting been changed.on wheel balancing done. alot time n money spent but cant troubleshoot d prob. your suggestion on what else to check n y is much appreciated so i can use the data gathered n explore with workshop.i intend to go by this morning...
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
which DS u changed to new? the short one?
from my experience the short ones are the same as pv6, so can be bought new.
the long one either u recond it or search at halfcut.
other factors that can cause vibrating, check rim for any signs of bengkok, tires bengkak, check lower arm, tie rod end, rack end, absorber link bushings etc.....
worst case scenario change steering rack.
hamtaro00
279
39
528
Ipoh
if rim got dent i think i can see it well when they are doing on wheel balancing right? i dont see any funny vibration. but when drive its diffrent. Danz, that guy told me 6a12tt got 3 parts DS. Left right and center. so he said alot cannot use. he change both left n rite.
steering rack been changed actually. recond. but i cant recall problem happen after changed or not. lower arm, tie end etc, what symptom to check?
EvolutionZ
5,000 RPM
5,027
1,448
absorber? check this too....expired/hardened tires..many possibilities
hamtaro00
279
39
528
Ipoh
absorber so far ok.. vibrate when exceed 90kmh. but after another round of fixing, 90kmh still got vibrate but when hantam above 105kmh very less goyang. steering and pedal also got vibrate. on wheel balancing countless time...lower arm etc checked ok
KenDiriwan
1,283
225
3,163
kendiriwan.multiply.com
The wheels hub, or whatever you call it, a small ring/alike fit into a small gap in middle of the nut after open your wheel.
hamtaro00
279
39
528
Ipoh
mazranz DS changed 4 recond and 1 new. currently on new unit.
kendiriwan all 4 corners wheel got the ring installed
hamtaro00
279
39
528
Ipoh
sexycar, camber test, i think got do on 1st repair. yeah myself was thinking to swap back rims to front too coz all the while we focus on front only. also im looking for other rim to test since now the problem kinda isolated to 90 - 105kmh vibration only. at work place so got to wait few more weeks before cuti and test again. meanwhile, thanks all for input
On wheel balancing, you should be able to see/feel it vibrate or do you mean during on wheel no vibration?
DanzEterna
15,911
3,371
3,213
PJ
its not 3 parts, its 2+1 parts the long 1 consists of 2 DS, some ppl call it DS gantung (famous among wira convert evo owners, quite a rare item though). but my long DS was 1 long piece.
The lone DS is in 2 parts, they try to even out the drive shaft final part to be same as the other one in length so that can minimize torque steer....
As i saw in my dad's waja there is a layer of sheet to sound proofe the firewall .... how do i do it on my wira as it starts to get noisy on 140 .... any idea ?
