if decellerate n vibrates?:hmmmm:engine mounting - car vibrating during idling
driveshaft - car vibrates during pick up.
your corolla which year & model?
i had this problem before.. it was the clutch. coz if in 2nd or 3rd it vibrates when foot is off accelerator. but when i press the clutch, vibration disappears.tq..buddies
engine mtg change d.
drive shaft i oso replace 2 liao.
its does not vibrate when its being idle.
jus quiet enough though.
occur only when u r engaging in 2nd gear thru decelerate..or 3rd gear etc.
in my case, yes.. clutch n pressure plate.. drive around with the mechanic before rectifying, play safe..i was thinking 2 test d injector by tomorrow.
perharps..
---------- Post added at 10:27 PM ---------- 6 hour anti-bump limit - Previous post was at 10:20 PM ----------
oic.so how u solve d problem.
did u replace d clutch set.
---------- Post added at 10:28 PM ---------- 6 hour anti-bump limit - Previous post was at 10:27 PM ----------
o..mine ride is a ae111 mt year 1996.
---------- Post added at 10:35 PM ---------- 6 hour anti-bump limit - Previous post was at 10:28 PM ----------
did u replace d clutch to solved it.tq
braking down is something we wanna avoidDecelerate is this when you braking down ?
To help us help you better, it'll be better if you could elaborate more on the issue.Any 1 could help me out?
I had change a lot of things.
Fuel filter
Plug
Cable plug
Distributor cap
Rotor arm
Fuel regulator
ECU
The shake symptoms occurs mostly around d 2nd n 3rd gear in 1800 to 3000 rpm.
