Braking issue
lukel95
75
28
GB birmigham
Hi guys, recently if i full lock to the left and then brake whilst reversing my brakes make a very loud sort of trumpet sound, any ideas?
Sent from my SM-G935F using Tapatalk
crazykatak
776
48
Subang Jaya
might indicate a jammed brake piston or uneven rotor.
working the rear piston is such a hassle and takes alot of patience lol.
from your description, it sounds like it is not releasing fully or releasing too slow.
i had the same thing about 9 years ago..right after that, I found out that the rear brake was going to be jammed (after changing new pads).
try looking at 2 areas:
1. Rear brake caliper assy (pin, piston, pads, cables); check out the condition.
2. Rear brake rotors (uneven wear , warped)
good luck
lukel95
75
28
GB birmigham
good luck
Okay great thank you, I also hear a quiet scraping noise when I brake coming to a stop and especially going downhill the noise will continue after releasing the brake.
What should I look for in the caliper and what should I do?
Also can you tell if a rotor is warped?
Spin the disc and see how it turns. If warp, as it spins can see it wave left and right
<img class="alignnone size-medium wp-image-35213" src="http://www.zerotohundred.com/wp-content/uploads/2012/08/crzspchrgd_1-600x399.jpg" alt="" width="600" height="399" />
The CR-Z is Honda’s take in bringing both hybrid and motorsports closer together, and it is taking an interesting journey so far. With already a thumbs up on the looks, the CR-Z is now slowly leaving its trace on the motoring scene like its participation in Japan’s Super GT race and also on our own 2012 TIMETOATTACK...
