Braking issue
lukel95
75
29
GB birmigham
Hi guys, recently if i full lock to the left and then brake whilst reversing my brakes make a very loud sort of trumpet sound, any ideas?
Sent from my SM-G935F using Tapatalk
crazykatak
776
48
Subang Jaya
might indicate a jammed brake piston or uneven rotor.
working the rear piston is such a hassle and takes alot of patience lol.
from your description, it sounds like it is not releasing fully or releasing too slow.
i had the same thing about 9 years ago..right after that, I found out that the rear brake was going to be jammed (after changing new pads).
try looking at 2 areas:
1. Rear brake caliper assy (pin, piston, pads, cables); check out the condition.
2. Rear brake rotors (uneven wear , warped)
good luck
lukel95
75
29
GB birmigham
good luck
Okay great thank you, I also hear a quiet scraping noise when I brake coming to a stop and especially going downhill the noise will continue after releasing the brake.
What should I look for in the caliper and what should I do?
Also can you tell if a rotor is warped?
Spin the disc and see how it turns. If warp, as it spins can see it wave left and right
HAi All V-tech Lovers.....
My ek 2 door in black colour plate no....WHS8033 Was stolen last sunday in taman desa,kl
the car is with15'' white p1 rim,the back bonnet wiper taken out but still got motor attacht...
both 2 side door n front bonnet got sticker kesan tat cant remove.........hope u guys if c the car can give me a call @ 012-3888406.....
AND TO THOSE ASSHOLE THAT DID IT........C THE NEWS SUNDAY....JANGAN KENA END UP KENA TEMBAK SAMPAI MATI!!!
AND HOPE THE MONEY FROM U SELL...
