Blinking In-Door Lamp,warning light. Do I need grounding cable?
arih
124
Sunway
www.resakse.com
hi all, got this problem after transplant to 6a12TT. My car now like not enough voltage, everytime I open door, my alarm system auto switch on hazard light (both signal lamp blinking)..when that happen, all inside-car lamp,clock,warning light keep fade in-fade out following that hazard light.According Volt meter in my Apexi TT,reading are 13.5-14.0 with engine idling. And when I keep pressing my auto window..voltage drop 1 by 1 till 13.0...I got pivot raisin VS installed but no G-cable as my old cap ayam g-cable not long enough to connect on this new engine. Is it problem with my alternator or do you guys think that Installing new G-cable can solve this problem?
thanks in advance!
jz now home, saw that my radiator indicator point more than 1/2, it is rarely happen!
wat's wrong????? :blink:
another problem is tat my engine more noise after service, is it due to the lubricant oil??? i jz change 2 a 10W-40 caltex from 15W-50 esso!
during service, i oso changed oil filter & plug.
