Blacktop AE111 gearbox with LSD
chorgiap
23
Hi, can I know if the gearbox with LSD for blacktop AE111 has 1 way, 1.5way or 2 way?
wfhan
4,339
96
selangor
The only 'confirmed way' is to dismantle it and see the actual thing itself...
anyway. u can ask sifu n0th1n about this, he has tested i think 20 dozens
4age gearboxes... hehehe...
btw, your 'new' gearbox is c52 or c56 ar ? managed to find out ?
chorgiap
23
Should be C56 dy lah dis time. any methods to identify or differentiate c52 and c56 from casing of the gearbox? I think LSD is better then w/o LSD rire? any disadvantages of LSD ya???
wfhan
4,339
96
selangor
differentiate c52 and c56 from casing of the gearbox? yes there is, i heard b4, but i personally don't know how...
LSD is better than non-LSD ? to say it is better or not is strictly personal preferences.. LSD will give u a balance distribution of power to the wheel. its intention is to balance both driving wheels' grip and makes driving more safe.....
err that;s what i know..well other siu, correct me if i'm wrong.
chorgiap
23
But would it (LSD) causing any inconvenient when driving??? Some of my fren told ntg just mr fun bt sum told got sound and jerking when it operates... which one true??? I mean for the stock LSD. thanks
wfhan
4,339
96
selangor
Got sound is because the gears of the LSD is doing something ma..
For stock LSD i don't think the 'LSD effect' is significant noticeable.
Even for me also sometimes confused. Some ppl told me BT auto tranny came default with Stock LSD... some said no.. some said all 6 speed GB got LSD, some said no.... how la..
maybe let other sifu enlighten us on this.
anyway, for more understanding of LSD u can read more here -> http://translate.google.com/translate?hl=en&sl=ja&u=http://page12.oboroduki.com/item_209932.html&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D41301-AE000%2B1way%26hl%3Den%26rlz%3D1G1_____ENMY247%26sa%3DG
(LSD TRD 41301-AW004 mechanical LSD )
(KAAZ Helica LSD)
read more at kaaz web
Kaaz USA Introduction To LSD
chorgiap
23
Hmmm...What i know is blacktop comes with 4 types of gear boxes.. 5s w/o LSD, 5s with LSD, 6s w/o LSD and 6s with LSD... correct me if i'm wrong. :hmmmm:
katopunk
464
right to a certain point. when you're talking about gb model like c52 and etc. it's not exactly 4 types.
chorgiap
23
c56 and c56 with LSD gear ratio exactlt the same???
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
mind if i share my understanding?
original equipped gb by toyota can have lsd or dont have lsd at all
lsd OE is called viscous
aftermarket lsd is when japs did something to these gboxes.
aftermarket lsd got many manufacturers, to name a few, trd, cusco, kaaz, ats etc
all of these is no matter what gb involved, c52, c56 or even c160 or c60
correct me if im wrong.
wfhan
4,339
96
selangor
haha finally situ n0th1n came to the rescue..
chargiap.
the gear ratio is the same no matter is with/without LSD.
right? n0thin?
Alcon06
322
The ratio would be the same regard-less of whether got LSD or not the difference is at the differential.
wfhan
4,339
96
selangor
what is the difference of on wheel power-loss comparing
c56 with LSD and c56 w/o LSD?
anyone did dyno b4 with both ?
to me, those scums deserved all the beatings...
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Dn5uP98nPfY&color1=0xb1b1b1&color2=0xcfcfcf&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/Dn5uP98nPfY&color1=0xb1b1b1&color2=0xcfcfcf&feature=player_embedded&fs=1" type="application/x-shockwave-flash"...
