Doubt about gearbox for blacktop ae111
chorgiap
23
Sifu, I'm using toyota seg ae111 converted to Blacktop with 5speed manual without LSD. My gearbox gone last week, went foreman thr replaced with another one. The foreman told me it is BT's original 5speed without LSD gearbox but what i felt is got different in gear ratio compared to the old one. How to test whether it is original BT's gearbox??? Before this 120km/hr at 5th gear = 3800rpm.. now 120km/hr at 5th gear = 3500rpm. I doubt he putting silvertop's gearbox.... any different between this two??? Or can it be ECU problem
Anyone using blacktop can tell me? Thanks :adore:
KHWONG
3,937
36
1,648
now gb u used could be from svt engine.. which called c52 gb...
Black top or end batch of SVT gb called c56 gb which has close ratio...
as u said... 3800rpm at 120km/h =bt gb cus i was using it.. almost same reading
fren using c52 gb .. slightly lower... hahha
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
err..
c56 and c52 using the same ratio on the 5th gear.
based on calc, using 195/55 series tyre, on 3800 rpm speed should be 117km/h. so confirm your old gb are 20v's
method of testing : you cruising at 5th gear, slowly climbing to 3800 rpm. and take your speed reading
possibilities: both gb have different Final Drive or different gearing
if using gearing from 4efte, at 3500 rpm, ur speed should be 125.3km/h
and your gearbox 'gone'? hard to engage? housing broken? what happened?
and lastly, happy researching!!!!
chorgiap
23
err..
I'm using 195/55/15 tyres. cruising at 120km/hr rpm = 3500 for dis gb. D old gb 120km/hr....
chorgiap
23
err..
oh ya, housing broken and 3rd gear can hear a crrrekkk sound when engage..
chorgiap
23
the old bt gb housing crack ande 3rd gear produce crrrrekkk sound when engaged.
chorgiap
23
I found another gb :5speed with LSD. Shall i put it on my bt? or 5speed w/o LSD better??? need opinions lah.. Thanks
Feilo
780
...Ipoh...
The LSD and Non LSD driving mood abit different.... With the LSD Gb need to used to it coz different control oledi.... specially when U turn and cornering....
burnner
1,563
4
with the same speed and same gear , you are getting lower rpm should be ok mah...better FC...Last time your rpm is 3800, now its 3500,consider good mah....
Adeen
2,726
6
kl
thats sumthing u have to consider for better FC though....hehehe:D
caleb_5375
1,293
14
go ask ur mech wat on earth he can change wrong for u ...or he tertukar wit others.......
chorgiap
23
Hi, can I know if the gearbox for blacktop AE111 LSD has 1 way, 1.5way or 2 way?
Hi All specialists....
does anyone have any recommendations for Brakes pads for my SGTI ?
feel like mine's almost finish.....
any recomendations for reliable, good... and of coz,,,, worth the $$$ to buy ..
please advise :):)
