Beep sound when lights on
gIGoN
327
anyone knows how to make a beep sound when we forgot to off the lights when the ignition is off?
mivecmerah
799
hehe
my car comes with the "teeeeeeeeeeeet" sound if u forgot to turn of the light!!!
sori...
gIGoN
327
my car also came with the 'teeeet' sound when forgot to turn off the light but then after my car was sent for spraying the other day.....the teeeet sound wuz gone dunno wat happened hehehe i think they forgot to rewire it back
darkbob
152
Johor Bahry
anyone has schematics on those wiring ?
how to ?
yewnen
39
Malaysia
1du.org
This can be done using a relay and a buzzer. I'm currently doing it. Will do it on this sunday.
The concept is using Relay to buzz the buzzer. The buzzer is connected to Relay and it is ON by the light supply. The Relay is triggered by the Ignition switch. So when the light is ON, Ignition is ON, then no Sound, but if Light is ON, Ignition is OFF, then the buzzer will BUZZZZZZ..... :wink:
yewnen
39
Malaysia
1du.org
I have done the soldering and I have tested on external 12V battery, it works satisfactory. Only 2 components: 1 relay and 1 buzzer.
There are 3 terminals, 1 connected to the car light, 1 connected to the ignition and the other one is common ground.
Hereby I attach a figure on how the thingy looks like. Will post the circuit diagram after install it to my car.
Cheers!
GTR
826
KL and Penang
www.strombergpowerbooster.com
next time dun send ur car to that car painting shop anymore. they have a bad "house keeping" habbit. i hate that type of mechanic/technician. :mad:
1 of my frens car's timing belt was broke bkos of the mechanic forgot to clear up the spannar on the engine bay after service.
another fren kena accident (bang by bike during turn right) right signal light did not function. the mechanic forgot to put back the wiring.
they should fully and proper check the car before handling it to customer. including the wiring and nuts.
kher
1,533
Klang, Selangor
Ya...this is good.
It will prevent u from forgetting to off ur lights n end up draining ur battery then canot start car.
My car comes wif it although an old 10year++ old car...
yewnen
39
Malaysia
1du.org
BlackMafia said:
ok ...
maybe u can make a bussiness for it ;)
Doing business of it? ha! It's only a small item. Not required any advance skills to do it wor..... Will install it to my car and try. If OK, then I'll post the wiring here.
yewnen
39
Malaysia
1du.org
kher said:
Ya...this is good.
yeap! It's good anyway, reminds you that your light is not switched OFF. hehe! My car doesn't come with this features. So, DIY lor........
yewnen
39
Malaysia
1du.org
The schematic drawing is like the attached diagram.
Only 2 components:
1) 12V Relay
2) Buzzer
You can add 1 fuse at each light and ignition wire to protect the item. :)
I've installed the item to my car. It works satisfactory. :) Happy DIYing... :rock:
lcchong
84
13
no image ar........... :idea:
Bump: where to wired it? :sleep::sleep::sleep:
to all the taikors
how do we know when to change our car clutch palate?
Pls advice
