He thought he could charge S$ converted price.......Maybe he thought singapore people dont have such high technology as using Alignment Machine He got to keep himself more updated then
RM35 for alignment+balancing...see number plate... oh Singapore $35...He thought he could charge S$ converted price.......
I think he wont even do your car, get out of my shop I can't afford tonext time i come with thai plate...should charge me cheaper....
Went most of Bangi area Tire shop but disappointed coz they can't do alignment on 19" wheels coz its too big, no ready stock for tires & everything need to order which takes couple of weeks....& the price they charge depends on what car u drive huh!Wah! that bad ah?
Thai number they charge you RM loh......next time i come with thai plate...should charge me cheaper....
Yup, normal machine can do 17" only. Even my regular shop last time had to upgrade new machines, both mounting and alignment ones.....Went most of Bangi area Tire shop but disappointed coz they can't do alignment on 19" wheels coz its too big, no ready stock for tires & everything need to order which takes couple of weeks....& the price they charge depends on what car u drive huh!
He does not even know your setup. I think he was thought to do camber from the bottom only...I was once threaten by one of the workers of another tyre shop that the alignment cannot be done perfectly if the camber nut is not replaced (as he said it sudah bengkok). Problem was..... my Putra don't use camber nuts...... its already on adjustables and camber plates.
Here are a few tips I have for those that wants to save a few bucks and a lot of hassle.
If you are changing your tyres, rims or balancing, there is no need to do alignment if:
- your car does not pull to one side or another
- your previous/current set of tyre does not show uneven wear
- the b@st@rd have not touched any of your alignment nuts
I used to go to a shop in USJ19 that is awesome in doing alignment. He will check and align with the machine then bring out his measuring tape just to be certain he does it right. And what I like about him is his honesty. No camber bengkok crap or other things that needs to be replaced when it is not needed. Unfortunately the shop is now operating as a Chevolet service center and no longer a tyre shop.
bengkok, if negative more stable mah......hahahahahhaaif they say camber nuts bengkok...u reply "its ok ma...bengkok so tyre faster eat one side so i ma faster come here change tyre...set?"
if positive...than like boat?:hmmmm:bengkok, if negative more stable mah......hahahahahhaa
If positive then give him business loh.....hahahahahaif positive...than like boat?:hmmmm:
