That answers the question. Change the clutch pump. I had the same problem... it only cost a few hundred ringgit.
Thanks bro, I'll keep that in mind~ But the problem is don't know I can reach Sunway without stall or not.....
---------- Post added at 03:56 PM ---------- Previous post was at 03:50 PM ----------
Twin plate clutch doesn't require you to floor your clutch pedal to engage a gear... 50% usually is good enough to engage a gear. (when you hear some of the "cling cling" sound) you are ready to engage. However, with the 50% (half clutch) gear engagement the moment you release your clutch pedal just even slightly you will be in drive already.. so get ready your throttle before hand.
I guess you will just have to get used to the twin plate clutch... if it is so unbearable change it back to stock. If you vehicle is equipped with hi-cams... even worse for city driving... thats the price to pay for powderful car. enjoy :)
Bro, after read again your info, i wanna make it more detail again. U mean only press the clutch pedal until hear "rattling" sound then can change gear already? I never tried this b4...... Normally i just flooring clutch pedal> shift gear> give some gas + release the clutch near friction point> slowly release clutch + adding gas. But the problem is..... fast abit also will stalling...... drive almost 1 week already still can't handle this clutch.
---------- Post added at 03:57 PM ---------- Previous post was at 03:56 PM ----------
I understand how you feel. Mine is a damperless clutch and it's a bloody bitch to drive.
Have you change your clutch pump later?
---------- Post added at 04:34 PM ---------- Previous post was at 03:57 PM ----------
naik kereta full throttle terus :p..jk jk
Later my car get smash by other ppl, LOL~ But serious, how many % of throttle is recommend for smooth start?
