my car is iswara aeoroback...
my current setup is
HU=pioneer deh6050ub
4 cannel amp=HTG424 lanzar
SPEC
4 x 125W RMS @ 4 OHMS
4 x 250W Max @ 4 OHMS
2 x 500W Max @ 4 OHMS Bridged
4 x 200W RMS @ 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs for 1/2 and 3/4 Channel
Low Pass Filter Controls
High Pass Filter Controls
Power and Protection LED Indicators
Soft Turn-on/Turn-off
THD: <0.04%
S/N Ratio: 90dB
Channel Separation: 65dB
Freq. Response: 15Hz~35KHz
Subwoofer Remote Level Control
Fuse: 20A x 2
Dimensions: 9.82''(W) x 2.34''(H) x 12.91''(L)
MONOBLOCK LANZAR
OPTI2000D
SPEC
700 Watts RMS Power @ 4 Ohms
1100 Watts RMS Power @ 2 Ohms
1600 Watts RMS Power @ 1.3 Ohms
2000 Watts Max Power @ 0.5 Ohms
4000 Watts Bridge Max Power @ 2 Ohms
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
COMPONENT SPEAKER
MB QUART DICCUSS 216 (FRONT)
DIAMOND M6 (REAL)
SUB
OPTI1222D LANZAR(2pc)
SPEC
Custom Tooled Die-Cast Aluminum Basket
Aluminum Alloy Cone Structure
Massive Butyl Rubber Surround
2.5'' High Temperature Dual Voice Coil
65 Oz x 2 High Density Barium Ferrite Magnet
Power Handling: 900 Watts RMS/1800 Watts Peak
Frequency Response: 26- 800 Hz
Impedance: Dual 2 Ohms Voice Coils
Efficiency: 86dB
Includes Installation Hardware and Template
Packaged In a Wood Box
CAPASITOR
5 FARAJ LANZAR
Above is my current ice, used 2 years already....
UPGRADING NEXT WEEK(ADDITIONAL AMP AND COMPONENT SPEAKER)
ADD AMP
1)4 CHANNEL AMP MXA 422 LANZAR
SPEC
4 x 250 Watts RMS at 4 Ohms
4 x 500 Watts Max at 4 Ohms
2 x 1000 Watts Max at 4 Ohms Bridged
4 x 450 Watts at 2 Ohms RMS
Bass Boost Circuit
Variable Phase Shift Control
2 Ohms Stereo Stable
Anti-Thump Turn-On
Tri-Mode Configurable
Soft Turn On/Off
High Low Level Inputs
Blue Light Illuminated Crossover Control
Power Protection LED Indicators
Advanced Protection Circuitry
Bass Boost Remote Control
T.H.D:<0.04%
S/N Ratio:>90dB
Channel Separation:<65dB
Frequency Response: 15Hz- 35kHz
Dimensions: 10.47''W x 2.46''H x 17''L
ADD 2 SET COMPONET SPEAKER
1)HELIX PRECISION H236
1)PIGASUS PG65
my upgrading planned is;
MB QUART (REAL) use HTG 424 4 channel amp
HELIX (FRONT DOOR) HTG 424 4 channel amp
DIAMOND AND PIGASUS WILL REAL BONNET (OPEN CONCEP) use MXA 422 4 channel amp
i will replace my all speaker wire when ugrading....based my current setup something i cant start up my car,when start no power delivery wait a while can start again..my battery is free maintanance one,last time my friend bring back from japan used one,i used it untill now more 2 years already..
thats all my info for u all sifu...any idel or suggest to my setup pls dont be hesitates give u expert suggestion...(now still looking around jb area for good installer,if got good installer in jb pls recommend )
thanks you ...:proud:
