Alarm problem
leynye yamin
106
22
518
Sabah Sandakan
Hi, i have a Aerosport kenari 05, i have problem with its alarm system & central locking system. It seems to work fine when driving. All locks can lock properly when the car engine is running. However, the problem starts after the car is turned off, and wanting to lock the car before leaving. There is 1 lock that is the driver door can only lock, the rest need to be locked manually.
Please help! What is the problem? the alarm module has been replaced last year. Is that i need to change new module again or the guns on each door got problem? I need to find out ASAP, i'll be taking the car for checking this noon.Thx!
pwhyze
924
356
1,563
Seems like the central locking mechanism that's the problem? Maybe not enough power from battery when engine is off? Could be a start...doesn't sound like the module to me.
leynye yamin
106
22
518
Sabah Sandakan
Guys, my problem solved d, turns out the original locking mechanism on every door has failed. ended up replacing locking mechanism ie the guns on all 5 doors. took out the original ones and modify the new gun type to each doors.
No need to change the module. Now solved d. Thx guys!!
Usually the guns do not fail all at once?....:hmmmm:
Dayline668
1,810
492
1,683
My wife car rear pass both die at the same time, now the rear door will not move after several lock n unlock. The front r still good.
wish to ask, Heard NA Camshaft Lift higher and longer compare Stock Cam
Which 1 would be better choice ? 4G91 ? 4G93 ?
Is there any marking on the camshaft ?
Estimate how much duration ..?
tq
