4G93 flywheel
alvin24
3,109
27
5,148
u can always go buy TODA lightened flywheel for mivec... 4G93 also can use, same size.
If you decide to skim your flywheel... take off 1kg max for reliability... else the flywheel might not be strong enuff, and might crack due to too much torture.
potssum
202
hehe tumpang lalu.... where can i get that toda flywheel for mivec?? how much does that toda will cost me?? i heard that if ur using lighten flywheel your top end will suffer plus u must always press the paddle so dat the engine wont loose its momentum due to light flywheel.. hmmm is it really that bad? any experince want to share??
Zeroed
1,705
45
You can get the RS Autosports ultra lightweight flywheel for that... I've held both original and RS flywheel before, the RS one is MUCH llighter compared to the original. My mechanic developed the flywheel himself, if youre interested PM me and Ill give you his number. :)
MaNofWaR
570
On the AiR
yup RS Autosports is light... one of my fren using it... but TODA is lighter (but i can't remember the figures) weigh both together, but TODA is very rare for 93/92 sizes & expensive.
whatever u choose...get the originally lighten flywheel rather than skimming it. lighten or racing flywhell has lesser mass but its made through R&D so the gains are guaranteed. u'll get better linear acceleration & better engine braking when dropping gear
safety first bro
Guys,
Plan to go light weight rim to replace on my existing heavy JRD rim.
RPF1 with 4.4kg / rim quoted RM2400. However, Lenso with 5.8kg / rim quoted RM 1100.
Understand that Lenso is mfg from Thailand, and is quite fresh for me on the rim quality. Therefore, would like to ask for opinion on Lenso rim. Any user here? can share? Thanks.:hmmmm:
