ayell,
4G91 gearbox is the same as 1.3/1.5 punya ratio... its memang pun already close ratio gearbox lar.... coz' 1.3 tarak power ma... so they had to make it close ratio. Pick up is good lar... but high speeds that time will feel like your engine struggling... coz' will be at damn high revs. If not mistaken... travelling at 110km/h on 5th gear, the RPM already will reach somewhere around 3.5k... now that would be okay on a mivec which drags till 9krpm cut... but ours cut at 6.8k man... 3.5k is more than halfway there liau!
Yong_5290,
I honestly think... drags are very subjective... there are 100 and 1 reason why a car can lose or win... unless of course the difference is too big. Like if someone said their 4G91 stock can tapau an evo3... u should just go and bitch slap him.
leacare CUZ,
U kau tim already give me a call lar... I'll have the JPJ runner setup for you. We 4G91 gang liau man... 4G91 Cuz! hahaha... Should ask gary to put 4G91 also... then whole family also running 4G91 satrias! hahaha...
tajulsans,
F5M22 means you're running on 1.6 gearbox. Good lar you.. i wished I had 1.6 gearbox also. Longer ratios better.... safe petrol, and highway cruising so much better. Hahaha... can play high end also... especially when all thoe BM or Merc come tiong u... acceleration can beat them... then high end have to move away... baskets!! But one thing though... 9" flywheel can fit meh? If not mistaken, max is 8.5... unless its an evo/gsr gearbox. And why would you want to have fit in a bigger flywheel? Would that make it heavier thus performance downgrade? So i'm assuming of course its lightened, that why you'll just have slightly better grip. Why not just opt for Racing Clutch for a 4G91... its available whut.
boyzone,
I had SAFC in my car once... dynoed the car, performance increase around 3+ hp only. Although max hp increase was little... the early and mid range power improved. Unfortunately my car was broken into, and the SAFC was stolen. Won't be getting it back... too much spent for too lil' hp gains.
