4G91 Gang..
Mar 18, 2013
Just got a 4g91 fuel injection Auto half cut, planning to install it into my old wira and replace the original 4g15 carb 1.5 auto which has terrible FC. Starts blowing out white smoke once i drive up to 80kmph.
Question is will i get more power in terms of pick up or mid from this 4G91 auto? Will the FC improve as well? This half cut mileage is already 160,000km by the way.
What do i need to change once this engine has been transplanted?
Many thanks.
iblizs
hi to all sifu out there can anyone tell me where@workshop to setting camshaft with properly tool to set hi cam for 4g9 series engine..
mugan shan
Jun 27, 2013
12
hello everyone...i am using 4g91 carbureted model using iswara stock carburettor.....is it possible for me to do open pod....like this in the picture attached...the first picture with red car is mine....i wanted to do open pod something like in the another picture attached
philippines
Hello there.Anyone can give to me the manual or diagram of 4g91dohc.Kindly send to my email at [email protected] you in advance...
I have currently problem with the firing order my two HTW no 2 and 3 are not firing.Any master/s here help me to rule out...I have changed the HTW and the ignition coil already..
Gilbert0999
92
Many thanks.
Hi there, 4g91 power is definitely better then 4G15 carb, For my opinion things need to change after transplanted is the timing belt, Lubricant, filters, and check those mounting n bush. Just my 2 cent.. :itsme:
---------- Post added at 03:58 AM ---------- 6 hour anti-bump limit - Previous post was at 03:54 AM ----------
i need air cond compressor for 4g91 engine?anyone
Hi there, maybe u can try this
Recond Aircond Compressor - Car Accessories & Parts for sale Kuala Lumpur - Mudah.my
Cheers....:biggrin:
ayell
808
4
Segamat JHR
Hello guys, any old frens still in here? :)
Mar 10, 2014
Penang
Hi guys,
I'm a newbie.. will be using 4g91 engine in 2 weeks time..
The car now in workshop for some repair... top overhaul and all..
Hope u guys can help me with some information when I need it.. thanks! :)
Jun 27, 2020
31
Hi, Anyone online here?
I need a big help. Can you please someone give me the pin out diagram of ECU 7375 ?
Thank you
current turbine is light pressure turbo and need to be change soon.. any suggestion for bigger turbine? that suit with the engine and doesnt need lots of mod..thank you
