Originally posted by Yong_5290@Apr 6 2005, 00:01
so any1 of us 4g91 gang using o tried Tufoil?
taljusan...i also using back my 4g13 gearbox....closer ratio tats even vios n city also kena tapau in pick up compare 2 tis old 4g91 1.5 ....
but cruising on the highway...true...sound like dragging the engine but then...this engine is very reliable.so far my fren use 4 3years(bought the halfcut already 80k mileage)...until now no prob...the main prob is the lifters sound
[snapback]872175[/snapback]
1.3 and 1.5 gearbox have the same ratios... so the only difference between your gearbox and a 4G91 gearbox is the clutch pump... you use back 1.3 g/box means u're running on cable... don't use racing clutch. If you do, the cable will tend to putus easily... else some other problems might arise in the long run. The cable can't handle the force.
