Dynojet can't clearly read my car RPM...
NeniNeniBoBo
377
34
Hopefully i'm on the right place to post and any sifu here can help me out. Just install bigger cc injectors into my car and is ready for dyno tune but problem comes out.... Its sounds weird, the dynojet can't 100% read my car RPM but others cars no problem, dynojet show my rpm jumping and fluctuate when give throttle, and sometime it langsung can't read my rpm and make my chart putus-putus.... Any problem to my car? I just change my coil not long ago(OKd), i think shouldn't be coil problem... A question here, will a bad earthing/ground cable will cause this happen?
zamiex
443
11
what engine? maybe ur cable plugs problem?... on mitsu engine its sometimes dynojet cant read rpm properly... maybe u should go use other dyno machine?
NeniNeniBoBo
377
34
Thanks for reply bro. My car is bnr34, rb26dett. Which cable do you suspect? Coil cable? Ground cable?
Problem is car like gtr35, gtt34, Honda all no problem, just my car....
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
try a different dyno machine with self learning/calibrating RPM. (something like dastek or hyper power).
it doesn't really matter if the RPM is out a little bit on the dyno. important thing is knowing the power & torque curve is right and optimum for your engine.
NeniNeniBoBo
377
34
Thanks bro~ will give it a try ^^
vteckiller
Supporting Merchants
1,606
34
yup try another dyno....
:p
Over Boost - Motorsports
Oct 11, 2010
21,312
11
638
Bandar Sunway
www.overboost-motorsports.com
aik, jo tukar dyno ke? :P
I feel rpm is very important to calibrate with the torque and powerband curve including air fuel ratio curve versus RPM, since all fuel and ignition adjustment is consist with RPM and other elements like intake press and tps when you wanna comes to tuning a standalone or piggyback rite?
Correct me if im wrong, still learning :P
Snap, Crackle and Pop easily defines the new BMW F10 M5 in the video above. The new Mon5ter, will no doubt set the standards for executive boy racer saloons. This time, they've ditched the high-revving 500bhp 5.0 V10 in favour of a torque inducing 560bhp 4.4 Twin turbo V8...
