Can't get my Airtrek to start.
aboo40
Aug 8, 2013
19
11
503
Aberdeen/Scotla
Parked up at the shops beside my house yesterday & when I went back to the car I can't get it to start.
Half tank of fuel & battery is fine but nothing when I turn the key to start it. No clicking nothing.
Anyone had the same happen to them or have a idea what it could be?
stutzedward
3,416
561
First thing that gets into my mind is yr battery. You said no cranking at all right?
How you know the batt is fine? Did u check the batt terminal connectors if it's loose?
If it cranks and still can't start then it cud be fuel.
aboo40
19
11
503
Aberdeen/Scotla
Everything works like heater, radio, lights on dash are bright & don't fade when trying to turn the engine over.
---------- Post added at 09:57 PM ---------- 6 hour anti-bump limit - Previous post was at 09:56 PM ----------
Also doesn't crank.
stutzedward
3,416
561
Bro, do you have an aftermarket alarm system? Could it be due to the immobolizer being activated? Usually, there's a reset switch.
stutzedward
3,416
561
There is hidden switch somewhere. Put in the key n turn ignition on. Find the button n press it.
4gbanger
1,958
386
1,683
Johor/ShahAlam
must be the starter as well.. get it checked.. i face this problem before. the starter's carbon brush need to change..
kaninbu
669
104
1,543
no sound when cranking mostly due to electric failure.check all ur wiring.worse case either battery or starter.
4gbanger
1,958
386
1,683
Johor/ShahAlam
there r few factor.. first its a battery. second its might be starter worn out or starter cable not in good cond. third, sometimes u need to put your gear at N then can start.
Starter not major mah!.....or is this your reason you tell HM so can change car.....hhahhahahhahah:biggrin:
Hie bros.I'm planning to mod my current hood with vents.Any bros here know which shop does a good work?Thanks a lot.Cheers! :regular_smile:
