Need Advise : 4AFE injector upgrade...
me2kimi
717
276
1,563
Puchong
Dear all sifus out there. I'm planning to upgrade my 4afe injector. But dunno which is suitable injector my the 4afe. please help.
Thanks in advance.
Dayline668
1,810
492
1,683
WHY the upgrade..? turbo charge already..?
me2kimi
717
276
1,563
Puchong
nop, stock 4afe. but feel lack of power. moreover my 4afe head has been PNP...
When driving below 2500 rpm, acceleration is very poor. But after 2500, throttle response quite good. that why I thought to upgrade injector.
TRD.AE92
780
40
How about just upgrade the fuel pump and install fuel regulator 1st?
me2kimi
717
276
1,563
Puchong
what fuel pump should i use? did you mean adjustable fuel pressure regulator?
Dayline668
1,810
492
1,683
4AFE is like that de ma... and add more fuel dun mean more power without proper tuning.. y not change the old o2 sensor 1st to restore its optimum A/F ratio. try it out.
TRD.AE92
780
40
depend on what fuel pump you want to put... but standard 4AFE not require high power fuel pump.
And yes, I mean that adjustable fuel pressure regulator.
I not sure your situation, but normally before upgrade injector, I will upgrade the fuel regulator 1st, then fuel pump 2nd, then injector last.
FGT
529
31
I agree with you coz factory injectors with factory setting operate in its optimum capacity, not maximum capacity. Since your engine have been PNP and as u said maybe it needs more fuel, cranking up the fuel feed might do the job, which I think the factory injectors is capable of doing it. Maybe a fuel pump from a bigger car will do the job. No need Walbro laaa, right or not TRD.AE92? Heheh.. but as usual with modding, u'll never know what'll happen until u do it..heheh.. All the best and pls update us after experimenting! :)
me2kimi
717
276
1,563
Puchong
Change O2 sensor with brand new one ker bro?
Already installed that AFPR, will test it soon....
cuscostrutbrace
987
62
3,028
No need to upgrade injector la...save money go makan-makan...4AFE is like that one...its not designed for power..
I drive stock 4AFE auto for 2 years and dont find anything wrong with it,its a nice engine,enough power for me..of course little power below 2500rpm coz 1.6 is still 1.6,small capacity so torque very little at low end...
If you driving manual,dont lug the engine below 2000rpm with high gear,of course you feel no power...for 4AFE auto,it is just nice at low end,but no high rpm power
Just my opinion only :-)
me2kimi
717
276
1,563
Puchong
Just want to add little more power to my 4AFE bro. I'm not hp hunger.
Anyway, I appreciate all your opinion here.
Dayline668
1,810
492
1,683
Brand new original O2 sensor lo.. When ur O2 sensor spoiled, ur F/C will go up, car no power. When change to new u will get the power bac to original state, not like new engine la cos engine aged ma. But u get the best of both world, restore power n better F/C. No need 2 waste money on other upgrade.. Save money for blacktop, or budget can go silvertop.
t-la
1,080
20
5,138
secret place
eh, i thought u already 'build' ur engine? if not mistaken u already change the internals.
i dont think changing to bigger cc inj will ad more power.....thats my opinion.
1 more thing, where u at actually?
me2kimi
717
276
1,563
Puchong
Dayline668
: I will change that O2 sensor next time.
Not build la, my 4AFE just been overhaul and at same time did PNP. Not change the internals.
I'm at puchong.
Drag91
137
changing the injector doesn't mean more hp or more fuel can cure the problem you are having if changing to bigger injector you will need management to tune back your A/F. Too rich also loss power. Thats what i think.
t-la
1,080
20
5,138
secret place
Dayline668
I'm at puchong.
oic...i tot u with trd.ae92 follow his project in mixing af together 4ag...
if u already pnp the cylndr head, why not u go for bigger exhaust header, bigger air intake and a lighter flywheel, i think it should produce a much better response.
me2kimi
717
276
1,563
Puchong
Bro, do you know how much brand new O2 sensor will cost?
FGT
529
31
i read somewhere in these forums brand new costs a few hundred...
Dayline668
1,810
492
1,683
Yea.. its not cheap.. I hav no info about price. Any sifu can giv some info here..?
me2kimi
717
276
1,563
Puchong
I better check my o2 sensor as levin818 post first.
guys i need help,
if i wanna change back my engine to stock GTi engine from VR4... is it hard to get approval?.... i travel long distance everyday so i need to control my fuel...
is it possible to trade in my engine for a stock GTi engine? how much?
thanks alot i really need advice on this..
