Need Advise - Speedometer Partially No Lights!!!
options
268
26
Hi Fellows Thread-mates,
I have a small problem on my e7 ride. My speedometer suddenly "blackout" with those affected area is the whole right-side (fuel, temp & evolution indicator bulb lights is off).
But RPM, Speedmeter, all others switch check light (engine check, ABS, safety belt, door etc etc) are ok.
Have verified bulb, bulb socket swap and fuse but the problem still the same. Can anyone gives a clues of what is the possible root cause? :stupid:
azizi.aziz
46
1,648
Han, bside speedo did u recog others blackout too like cigarette lighter, cd player or main rear brake light...
if not...to narrow down your problem...can try plug n play with other member speedometer...
options
268
26
Only the light did not turn on, may be should try to plug other speedometer.
Thanks.
PabloIceman
3,083
291
1,683
Thanks.
Han, straight away change to Ralliart meter or better still Stack Meter laa ... :adore::rofl::thefinger:
Your car preparing for Major upgrade liao maa ... might as well change to the above meters .... :rofl::rofl:
options
268
26
Stock already so many problems already ... wanna upgrade to get more headache ahh ??
options
268
26
That's good bro, u cannot see the speed, it wont mentally limit u from going faster ... then u can challenge ur limit now ... ha ha
kampoon
1,205
89
1,648
check the bulb first....then check the incoming current....and then check the circuit....then socket....then switch....ecu...fuse...battery...alternator....bra bra bra....if too troblesoom......just hantar to reliable wyreman to check.....make sure they knows...ur ride wiring....
options
268
26
problem solved. Thanks to all. It was to contact issue ad one of the bulb changed.
good daty my brothers, just found out that I'm in the list also. My car got broken this morning and I found out bout it 30 mins ago. The car was park in front of my house. here are the things that got stolen.
1. my CD/mp3 mostwell HU
2. MY audio phonar amp.
3. all the RCA cables(with plated gold head)
4. one auto gauge volt meter.
5. Rear Passenger side small window.
so damn piss now. Any if anyone comes across anyone selling the above mention things hope you guys can just give the fella a...
