- Mar 28, 2009
- 91
- 0
- 1,506
I think brand new do not have already, since it is very very old item already, secondhand about RM 350+-how much does the Greddy Profec E-01 display monitor cost??
thanks for the info bro...I think brand new do not have already, since it is very very old item already, secondhand about RM 350+-
http://www.lelong.com.my/Auc/List/2...TION_-Greddy-Profec-E-01-Original-Monitor.htm
GIve this guys a call he always go japan sometime one, he may be can find for u(he also same guys selling)
i got buy brand new Avc-r and blitz DCII meter from them very fair price and quick service confirm.
monster mpv with turbo undergo ya goodthank you for this info mr limfk...he.he.he
cannot, but i can watch your engine information(like oil temp oil pressure water temp etc) with the Greddy Profec E-01Can watch TV/DVD?
second hand should be RM350 can buy athow much Greddy Profec E-01??
where it can be install(workshop)??
where it should be place in my car??
Bump: how much Greddy Profec E-01??
Gud info bro..IT is piggy back ecu, it has 16X16 mapping = 256map.
or it call sub-computer in which the airflow sensor signal or the pressure
sensor signal can be mapping to fine tuning the car each map to in order to to increase/decrease fuel for each engine revolution.
Even in light tuning such as an air cleaner/muffler replacement, a shift in air/fuel ratio occurs in greater or lesser degrees. This is due to the difference between the airflow detected by the airflow sensor and the actual airflow caused by a change in the airflow that passes through the airflow sensor.
The e-manage can correct this difference to set the original air/fuel ratio and increase the power. It also has various functions such as a VTEC control function and a function to prevent engine stall.
Furthermore, it can be used as a meter to check vehicle conditions with various monitoring functions. But need to buy the Greddy Profec E-01 to check vehicle conditions.
it is something like afc neo also but have more map than the afc neo.
AFC neo 16X2 map
E-manage 16X16 map
F con is which have 16X24map
remember the more the mapping in the aftermarket ecu the more precise u can tune your car.
But if your car are under 400HP not recommended standalone is not worth the investment.
RM950 for blue e-manage with out harness
Rm2100+- for ultimate e-manage with out harness
so clear yet, hope u understand.
Happy modding dude!!
Just only oil temp,water temp,oil press,etc??cannot, but i can watch your engine information(like oil temp oil pressure water temp etc) with the Greddy Profec E-01
Gud info bro..
how about the emange blue compare with the emanage ultimate?
emanage ultimate mapping range?
---------- Post added at 08:57 PM ---------- Previous post was at 08:44 PM ----------
any others features on the profec E-01??
can work with e-manage??
