Questions about Camshafts
superkoh
40
can ask all the gurus here, what's better on either b18c-r & b20, please give in terms of Durability come first.
1. Jun stage 3
2. skunk2 stage 3
3. Toda C
4. BuddyClub Spec V
5. Crower Stage 2
what valve spring retainer to go along? Anybody using supertek? Any comment?
And cam gear. KUDOS
D-IV
262
To start with, what is your application?
2- Whats your compression?
3- What RPM are you planning on revving to?
The supertech is the same as any other as long as you match the lift of the cam to the valve spring and keep the seat pressure reasonable with the springs.
Cam gears, I would use the same brand as the cams itself rather than mix and matching.
superkoh
40
i don't plan to rev up to 11k or so-ever. The most also would be 9.5k, daily driven with occasionally up to 9k.
doing up a b18c-r
---------- Post added at 10:21 PM ---------- Previous post was at 10:20 PM ----------
if i were to take buddyclub i need to take its cam gear, which is more advisable since its from the same manufacturer? vice versa
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
team99ers.2.forumer.com
the cheapest way or the easy money way...???
how many horse do u expected & the most important is, which management u will consider 1st...??
can just pass a few spec for u for reference...
D-IV
262
Not a lot of cams would make power up that high RPM. When talking about reliability, any engine would get stressed revving up to that point but let the others chime in regarding this.
Toda C would be my choice for ocassional high rev based on your list.
But my personal choice for a daily driven application, I would settle with BC 3 cams (fat midrange) or skunk2 tuner series stage 2 (nice top end). It works well with CR of 11.5-11.8:1. But ofcourse everything has to be tuned on a management system like Jin said.
caleb_5375
1,293
14
all the cam above can let u get through 200 horse on wheel..
the higher duration the cam go the higher the power band at. the more lift got the more power can get by without reving so high up.
but one thing i advice is to used bak the stock cam pulley and mod it like adjustable one...toda cam pulley will worn out oso...aerospeed that i used now same...it will makan timing belt...
if u seek a builder for u pls PM me....i got a fren can do all that for u ....
---------- Post added at 03:04 AM ---------- Previous post was at 03:01 AM ----------
oh yeah u need to have a high compression piston to run good on it....bcoz the higher duration open the shorter the compression stroke duration..that y u need high dome piston to compress the air fuel mixture...
the best ECU for ur upgrade i recommand is hondata...coz nothing run honda engine best then honda ecu... cheerS~~~~
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
most of us here encounter the prob of higher CR bout 12-12.7.... after the cam & head done... will get very nice figure of power when pump will V-Power(to prevent knocking), but not really suit the others petrol... spark plug using 8.
superkoh
40
i always pump petronas.
i might go for jun3 or skunk2 stage 3, if not i'll go for my builder recommendation, buddyclub spec v.
but about the cam gear, use a adjustable one?
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
ofcos....
i oso reco Spec V..
caleb_5375
1,293
14
i am now trying skunk2 P3...din take my car yet....when done all the dyno and tuning i will share out lah the horse it makes....my tuner oso recomand spev V ...but i wan try out the skunk2 first... good luck for u bro...
BRO JIN wat cam u using now ?
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
i'm just pomen... so, give suggestion only..
caleb_5375
1,293
14
izzit ? wheres ur workshop ?? penang ?? i not pomen lah but honda technician...the low low level one lah ...haha....dun laugh me if i say wrong at here ah.....
cabut ~~~~~
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
cabut ~~~~~
nop, at PJ area... won't laugh la.. coz we not talking big without proper thinking... we just discuss only ma...:adore::adore::adore:
caleb_5375
1,293
14
oic ....PJ where ? when free come find u lor...i just apply wat i know to share around here oso ...lets get bak to the title ..cams cams cams
D-IV
262
Compression is one thing, displacement is another. Try honda-tech forum and see what kind of displacement they are using or maybe somewhere there is some information that would suggest the displacement along with compression for different types of camshafts.
I just think that the BC V's are just too wild. But at the end of the day, your builder, your tuner and your money.
Hi guys. Just want to share something with you out especially for those whose driving Proton Waja. Last CNY while on my way to JB i take a break at Seremban R&R for breakfast. Take a break around 15 minute.Then went back to car then start it up.Few second after that my engine suddenly die.Try to crank back but nothing.Its cranking well just wont start.I suspect battery flat out sing the night before I do some upgrading work for my ICE. Temporally disconnect all recently make connection and...
