Vibration when starting to move on 2nd gear
slick
615
14
5,018
www.slickworx.com
Hi guys,
I have a question.
When my car is stationary and I try to start moving on 2nd gear, while balancing the clutch, the car vibrates.
At first i thought it was normal as it only vibrates a bit and some other members say they experience the same.
But over time, the vibration became more and more, and now it's quite violent.
Anyone knows why this is happening?
Engine mounting? Clutch? Anything else might be the cause?
Thanks in advance.
prasath_5338
1,131
19
Maybe its your mounting! Or can be your clutch also!
When first bought my car, i usually use gear 2 to move from stationary. after mounting and clutch replacement it seems impossible as the car will vibrate.
solution: pay a visit to john.
slick
615
14
5,018
www.slickworx.com
AFTER REPLACEMENT of mounting and clutch then the car vibrates?
Will pay john a visit, maybe today lunch time....
subcon
1,442
49
Turn 5
why didn't you use 1st gear to move from stationary?
slick
615
14
5,018
www.slickworx.com
Traffic jam sometimes malas la bro, u know la, our gear box close ratio, very fast have to change gears already, so if traffic driving i normally skip gears.
Not just from stationary, sometimes very very slow moving then i balance on 2nd gear
Vagabond
1,731
53
1,648
I tend not to skip any gears ..... whether upshifting or down-shifting.
i'm not even sure why i do that ..... practice perhaps? :biggrin:
bb1-man
637
25
3,028
no shit timmy. i know a guy who heel-toes on downshift even in city traffic....practise? :D
but..don't you think balancing the gear on 2nd gear for standstill-launch would wear out the clutch faster?
i always think quick engagement of gears can prolong the clutch's life....
slick
615
14
5,018
www.slickworx.com
Might be true about wearing out the clutch faster when standstill-launch on 2nd.
But actually i don't use 2nd gear when the car is at full standstill. I do it when it is moving but very very slowly to the point i still have to balance clutch a bit on 2nd, that's when the vibration happens.
I mentioned standstill-launch on 2nd because that's the easiest way to replicate the vibration problem, and it's easier to describe the scenario.
You guys face this same vibration problem as well? Regardless standstill or non-standstill 2nd gear balancing? Is it normal?
Vagabond
1,731
53
1,648
heh heh ........... i remember dcLoo's k24 ....... so powerful & torquey , really had to launch in 2nd gear ....... 1st gear couldn't get any traction at all.
Bump: Slick , i think what you meant is "juddering" ........... and no , i don't think it's normal ............
should take it for a check up , experienced mechs will probably know what's the cause of it
as long as the problem is constant, and not intermittent, it shouldn't be too difficult to troubleshoot
slick
615
14
5,018
www.slickworx.com
Thanks Tim, will bear that in mind.
minivan
1,793
121
BBBangi/KL
In one case i've seen, is that one of the bolts that hold the drive shafts in place (theres 3 bolts on each side) went missing as it came loose... just one of the things to check la....
boulala
461
15
just change to k24. then you can move from stationary using 2nd gear. or perhaps 3rd gear..
There's a lot of brands...so much.Could anyone tell me which brand and model is the best for VTEC engine?And what brand is OK for VTEC becoz the BEST must be expensive?Got low budget la Bro..Tq.
