Vibration during acceleration and braking
YYC
1,833
939
Hi what could possibly cause the vibration to Perdana V6 during acceleration and braking? The vibration is felt during mild acceleration as well as light braking only. No vibration is felt during hard driving and braking.
I have replaced the front brake set, both lower arms, as well as both driveshafts. It still happens. What else?
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Not very sure....
But i think it could be the...
(1) Engine mountings need replacement
(2) Gearbox mounting need replacement....
No harm checking....:listen:
YYC
1,833
939
erm disc brake?
Already replaced another set, skimmed. No effect.
Not very sure....
Yes I think there is at least one engine mounting is gone.
Unbalanced tyres or dented rims.
And rotors skimmed? Or replaced?
Maybe tyre balancing problem , damaged wheel... need to check.
Yes rotors, calipers and pads have been replaced. Rotors skimmed. Problem remains.:confused:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
perhaps tie rod/ tie rod end woth checking also....
including alignment/toe setting
headshot
160
Malaysia
same with mine, while pick up from 70km/h my mech found that bearing at drive shaft is wrecked, changed the bearing not drive shaft problem solved
YYC
1,833
939
Just wanna update the progress.
I raised my car height by 20mm front and rear, the vibration has reduced in both circumstances. I think what my mech said was true, car height too low stressing some components like driveshaft causes some unpredictable problems like vibration etc.
spoon civic
403
36
528
terengganu
means too lowered can cause vibration?hurm.....:stupid:...maybe....
Yes, I had that problem too when I lowered my front. After change back to original height no more problem. This is due to the angle of the drive shaft, when lowered....
G221
Over 10,000 RPM!
13,344
61
Have u checked your suspension bushings? Vibrations may occur from worn out bushings too.
CYLINDER HEAD PORTING AND POLISHING
Maximum engine power depends very much on the rate at which air can flow into the cylinders. Airflow efficiency is dependent on the design of the air intake system and the cylinder head. One of the factors that affect the peak power output of an engine is maximum port flow at the cylinder head.
However, always remember that peak engine power (max. hp @ RPM) is NOT the most important consideration for a road car engine. More critical is the average...
