IK20 or IK22
B16B Corolla
562
10
Hi,i am newbie here and i was just convert to BT auto. What is the best spark plug for this engine what is the difference between IK20 and IK22? Which one better for BT? And how about nology plug? Thanks for all sifu's advice.
Vagabond
1,731
53
1,648
IK20 is heat range 5 and IK22 is heat range 6, if not mistaken.....
it would depend alot on your engine mods. if you find that heat range 5 plugs are burning up (charred) too fast ....... then you should upgrade to a higher heat range.
my advise on spark plugs: a spark plug is a spark plug. it's function is just to create a spark.
don't bother wasting additional $$$$ on 0.0001 whp.
cybtech
408
6
ya IK20/22 just the heat range differences, IK22 normally use for turbo/supercharge engine (correct me if i'm wrong here guys)
I'm using IK20... not bad
btw nice nick... combines two parties (kacuk)....:biggrin:
TRD.AE92
780
40
IK20 is stock. IK22 can be use on NA or supercharge too... IK24 much for turbo use.
B16B Corolla
562
10
how about the brand such as DENSO, BOSCH and NGK?
Another question, if I wanna use BZR head to our local seg AE101, is it possible?
Any modification needed?
When i bought the half cut come with the Levin ori muffler but i was thinking of the twin from 101. Which one better fot A/T?Anyone tried before?
TRD.AE92
780
40
About the spark plug you may refer the reply thread that provide by Dayline668.
BZR head to local SEG AE100? 1 word for you... are it worth, and you got so much money to doing so? If your answer was yes... go ahead, the ketuk body guy can do it for u. But alot of modification is needed!
A/T better to use stock muffler or small tips muffler. Or else you may end up with waste money again.
dennisdreams
333
21
IK22 all the way ^^~ IK20 is still too-cold for 20v, BT or SVT~ if you keep revving to red-line~
lonelylilpig
832
33
refer to the tech data, 20V white top / black top best suit with spark plug heat range of 6 for NGK, 20 for Denso
Bump: refer to the tech data, 20V white top / black top best suit with spark plug heat range of 6 for NGK, 20 for Denso
TRD.AE92
780
40
Huh? 20V nowadays got white top already ka?
t4kak0
222
LOL,sure ar bro?
Than got any side effects or not if using ik22?Another question, now I just convert my engine and left the master pump. I already modded the twin port but just wondering will it be more efficient if use the dual-layer brake pump? Any moddification?TQ.
Bump:
LOL,sure ar bro?
Dear bro, Can someone tell me how to modify this engine. it is tough because it is just SOCH Vtec instead of DOHC Vtec. moreover now i'm using singapore plate. what i can think of is to try on Port ad polish,UNIChip or E-manage piggy back,speed meter to check if there is speed cut or not. the rest, i do not know what to do anymore. i just feel that my current engine is so weird because on my 1st gear (auto), it can ram to oly 5500 only then change to second gear and can ram to only 6100++...
