Seeking advice from senior about car modification to the maximum power
frank118
435
24
Yeah strap a an F-15 jet fighter engine...there you go 20,000 lbs of thrust power for you!!!! lol
But then maybe you would have to sit on the engine?...hmmmmm
ettm_14
605
81
yeap K&N is good, depends on your transmission also and what car you driving,
weihangoh
9
yeah.....maybe F-22 raptor engine too.....
where can we get those engine???????
wow,cant imagine how would it be if we put those engine into our car.....
Bump:
somehow i alwiz recommend ppl to get drop in filter for street use... but if u want better performance at mid-high rpm, getting an open pod filter also wise....
try enquire from a forumer here in zth... kangyoon.... reputated seller...
besides air filter,what next should modified???
ettm_14
605
81
after air filter maybe you can proceed to get a lighten crank pulley for more pick up?at least you will feel your car lighter...
definitely worth the money!
mizunori77
1,387
1,041
there are BOT options for vios or you can swap in a eterna tt for ur perdana. browse around in zth, i'm sure you'll find a lot of useful info that you can use. happy modding :)
weihangoh
9
can you tell me moro info bout eterna tt???
thanks for ur help....
Bump:
how does crank pulley works actually?
wat brand is recommended for crank pulley??
usually wat is the price????
thanks for all ur help...
frank118
435
24
Lightened crank and cam pulleys is minimal if you have standard cams..although it revs a bit faster...maybe its psychological.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
crankpulley drives ur auxiliary belts (alternator, water pump, aircond compressor, etc) from ur crankshaft... basically by using lightened crankpulley, u reduce the rotating mass of ur pulleys... effect is somewhat similar with using lightened flywheel... ur rotating mass will be lesser, less inertia, better pickup...
674
15
dear weihan,
let's start with RM500 and i tell u what can u do with this amount of $$
- Skim engine head RM150 (improve respond significantly)
- Skim flywheel RM150 (improve acceleration)
- Pro Rallye Cables RM180-200 (improve engine powerband especially high rev)
I garenti these 3 things done, you will be having fun for at least 1 month......:driver:
then u ask me again, i will show u other poison :)
weihangoh
9
dear weihan,
hahaha...thanks man....
also wat brand u would recommend me for the flywheel and etc???
after these 3 things done,wat should i do next to increase for more power???
ur help really helps me a lot...
thanks....
BBRAYCER
3,076
www.bbraycers.com
thanks....
collect money and stary buying toys and more toys :listen:
:adore:
crank and adj cam pulleys
high lift cams
better grip cluthches
check my topics to find out . links to our catalog
gud luck padawan soon you will be yielding a large turbocharger! :bawling::driver:
Mar 21, 2008
674
15
thanks....
errr....skim ur bone-stock flywheel, not buying another one...duh....sorry if i confused u :)
limfk7
211
19
PENANG % KEDAH
easiest way buy complete engine from cosworth, JUn or tomei. But prepare at least 70K malaysia ringgit for sure. No need headache what crank or rod or piston can build the strongest engine.
Mar 21, 2008
674
15
haha, 70k can buy RX7 liao ler
limfk7
211
19
PENANG % KEDAH
True this maximum modification to do it lo and let professional to do it lo(from what i know if you ferrari F360 and you let NOVITEC from overseas to tuned and upgrade you ferrari for another 100HP the cost is about RM250,000). Rx7 if u want to buy also better no buy lo it rotor then ti brake down at every 60K mileage.
For best buy some US like cp piston(can boost 2 bar), eagle rod(boleh tahan 600HP). to increase you car performance i think if u can order direct from us is very cheap for cp piston about RM 1925(without delivery fees of course) but in malaysia they sell for RM2900, if eagle rod it is cheap also RM 1155(without delivery fees of course). CP piston can customised whatever piston u want but only the money is the main problem only.
If u have extra money put sleeve in to your engine block example darton sleeve, it cost about AUD$550. If install this, confirm u block can withstand 55psi for sure.
engine internal part have been strengthen you can put some big turbo like gt3540 and gt3037s for 2000cc engine if u have 3000cc u can put to4Z ot t51R kai and some good ecu like motec or haltech but cheapest still is F CON V pro to squeeze the maximum power of your engine.
Port polish increase you valve by 1+mm in order increase you combustion camber and good air flow, put high cam like 272 degree and open pod air filter, to increase the rpm range and some power also at least 30HP gain(crank hp). if can put another okada plasma direct coil to u.
But in order to cope with that to prevent the clutch slip u must upgrade some decent clutch like ogura twin plate or os or exedy about RM4500+-
but after increase for so many hp u want stopping for sure for upgrade cheaper kit is VTTR rm 5K+-
but u want ultimate stopping power choose ap racing but prepare to pay 10k above.
For handling
For suspension i recon tein, not HKS hipermax because it tend to have noisy coilover after use for a long time.
if want to further minimize body roll and direct feel of road condition change your bush to pu bush such as super pro, whiteline and powerflex.
Is this help u? :)
chocolatesttarfish
1,041
68
PJ/BTU
weihangoh, like many othershave mentioned, you need to be more specific about what you want to know. your question is too general so the answers to your question will also be very general. in this case, it may or may not help you or others who go through this thread. its like you go to the doctor and just tell him "i'm sick. give me meds." how to give you meds when the doctor dunno what's wrong with you? be more specific lar... like what car are you driving and what do you plan to do with your car (street/track/rally/drift/vip/bangbus/etc)?
:rofl::thefinger: i think u downloaded 2 much porn :rofl::rofl:
weihangoh
9
:adore:
high lift cams
hey,thanks man....
ur catalog really helps me a lot...
do u still have others catalog?
Bump:
:adore:
high lift cams
hey,thanks man....
AD_EG
6,328
231
Ipoh
dear weihan,
I didnt know changing plug cables can FEEL the difference...
but the other 2 is fine.
It was a long time coming and the moment has finally come upon us. Nobuhiro ‘Monster’ Tajima has smashed the 10 minute barrier up Pikes Peak with a blistering 9:51.278 run up the hill.
We’re going to say that this probably ranks up there with the greatest moments in sporting history and no amount of video or pictures could ever begin to even give a glimpse of the atmosphere and emotions during that...
