ya cleverYeah strap a an F-15 jet fighter engine...there you go 20,000 lbs of thrust power for you!!!! lol
But then maybe you would have to sit on the engine?...hmmmmm
yeah.....maybe F-22 raptor engine too.....Yeah strap a an F-15 jet fighter engine...there you go 20,000 lbs of thrust power for you!!!! lol
besides air filter,what next should modified???somehow i alwiz recommend ppl to get drop in filter for street use... but if u want better performance at mid-high rpm, getting an open pod filter also wise....
try enquire from a forumer here in zth... kangyoon.... reputated seller...
can you tell me moro info bout eterna tt???there are BOT options for vios or you can swap in a eterna tt for ur perdana. browse around in zth, i'm sure you'll find a lot of useful info that you can use. happy modding :)
how does crank pulley works actually?after air filter maybe you can proceed to get a lighten crank pulley for more pick up?at least you will feel your car lighter...
definitely worth the money!
crankpulley drives ur auxiliary belts (alternator, water pump, aircond compressor, etc) from ur crankshaft... basically by using lightened crankpulley, u reduce the rotating mass of ur pulleys... effect is somewhat similar with using lightened flywheel... ur rotating mass will be lesser, less inertia, better pickup...how does crank pulley works actually?
wat brand is recommended for crank pulley??
usually wat is the price????
thanks for all ur help...
hahaha...thanks man....dear weihan,
let's start with RM500 and i tell u what can u do with this amount of $$
- Skim engine head RM150 (improve respond significantly)
- Skim flywheel RM150 (improve acceleration)
- Pro Rallye Cables RM180-200 (improve engine powerband especially high rev)
I garenti these 3 things done, you will be having fun for at least 1 month......
then u ask me again, i will show u other poison :)
collect money and stary buying toys and more toyshahaha...thanks man....
also wat brand u would recommend me for the flywheel and etc???
after these 3 things done,wat should i do next to increase for more power???
ur help really helps me a lot...
thanks....
errr....skim ur bone-stock flywheel, not buying another one...duh....sorry if i confused u :)hahaha...thanks man....
thanks....
haha, 70k can buy RX7 liao lereasiest way buy complete engine from cosworth, JUn or tomei. But prepare at least 70K malaysia ringgit for sure. No need headache what crank or rod or piston can build the strongest engine.
True this maximum modification to do it lo and let professional to do it lo(from what i know if you ferrari F360 and you let NOVITEC from overseas to tuned and upgrade you ferrari for another 100HP the cost is about RM250,000). Rx7 if u want to buy also better no buy lo it rotor then ti brake down at every 60K mileage.haha, 70k can buy RX7 liao ler
i think u downloaded 2 much pornweihangoh, like many othershave mentioned, you need to be more specific about what you want to know. your question is too general so the answers to your question will also be very general. in this case, it may or may not help you or others who go through this thread. its like you go to the doctor and just tell him "i'm sick. give me meds." how to give you meds when the doctor dunno what's wrong with you? be more specific lar... like what car are you driving and what do you plan to do with your car (street/track/rally/drift/vip/bangbus/etc)?
hey,thanks man....collect money and stary buying toys and more toys
crank and adj cam pulleys
high lift cams
better grip cluthches
check my topics to find out . links to our catalog
gud luck padawan soon you will be yielding a large turbocharger!
high lift cams
I didnt know changing plug cables can FEEL the difference...dear weihan,
haha... oopss...I didnt know changing plug cables can FEEL the difference...
but the other 2 is fine.
