Proton 4g13 Power Steering Weird Sound During Turning
viostar
475
2
Anyone can help?
Power Steering with low weird sound during turning!!!
Can it be service?.... By changing the Power Steering Fuel? can solve & stop the weird sound!
Pls give suggestion or advise?
Thanks.
g88
3,081
54
5,148
what is the weird some coming from ? How's the sound like ??
majavaz
28
2
1,503
check your power steering hose, maybe there are some leaking.. for the moment try check and if necessary add power steering liquid first..
viostar
475
2
The sound appear during turning. Can easily hear the sound clearly when car stop & just turning the steering.
Bump:
Okie fren..
I check first... Thank a lot.
realplayer
330
hye viostar...izit that sound like "bergesel"??...my car's steering sound like that..huhuh..still wonder why...:rolleyes:
viostar
475
2
I think sound like what u said! but only during turning time.
How huh? how to solve? or the power steering soon wanna "Kong" ka?
Any advise ne?
realplayer
330
Any advise ne?
yeah..same like me...the sound come out when turning.....still donno how to solve this problem..my car (wira) allready 9 years old, i think that a normal case..hehehe..and one more thing, the steering quite heavy
i allready check the power steering fluid, and it's at normal level....it's still mystery bro...
any sifu's...please healp us..:biggrin:
ExceL
1,726
162
Ampang/KL
Does it happen when you turn almost full lock? aka U-turns?, I use to have a knocking sound..mechanic said its was my drive-shaft, however it cured itself several days later.
realplayer
330
wah excel....cured itself??:biggrin:...what a nice car..hehehe..in my case,even i turn just a bit,it come that sound...as i know, if drive shaft problem, it sound "ktak-ktak" when make a U turn, right??..:confused:
viostar
475
2
ya...ya... even little turn also sound but not loud.
drive shaft ..... once spoiled than must change liao.
Your steering heavy ka?? what size of tyre u using now??
Or you try to service the power steering fluid first... take out the old fluid replace with new fluid first might help na!!!!
Aiyo... how to solve the sound ne!!!!! my car same as your yr99 almost 10yrs liao.
realplayer
330
maybe 9 years car will come this problem...hehhe..i'm using 14" inch rim only...but the steering abit heavier then other wira (i have try before..). ..when highspeed, best woooo...when side parking, like auntie..:rofl:...acctually my car have a idling problem( TB kong!!), when the RPM just 800-900..the sound came out, but when i set the RPM around 1000++,...the sound gone....my car is green colour, and i call it "the mystery green machine"..:listen:
viostar
475
2
Hey do you install grouding & voltage stabilizer on your car? It might help & get the car more stable.
Have you do any modification on your car yet? If yes, might to share what did you mod?:driver:
realplayer
330
i not yet install the VS......acctually i install a piece of "toyota" thing..i donno what to call but my mechanic say it a "vacum controller"..but in not that FICD..it can set the amount of air...you know la.,when TB kong,on the AC,the RPM will drop...after this modification, abit better la...for the RPM,not really consistant,sometime ok(1000RPM)..sometime lower then 800RPM...when lower then 800RPM,the sound came out...for now,the sound gone for a while..hehehe:listen:
viostar
475
2
Hey friend,
How much you got the "vacum controller" installed?
Yup, I read from forum some of the ZTH member did installed it. Some will good feedback some are not! So I am thinking to get one as well.
The said go for "FICD" Fast Idle Control Device.... But are your's is the FICD??????
For this few days, the weird sound gone... I might need to see further it might come back neh.
I replaced the ori plug cable with "Pro Ralley High Performance Plug Cable" added with Bosch Super4 spark plug..... Can feel that the car gainning some power compared to previous with ori spark plug & plug cable.
Might wanna to try out the Pivot Voltage Stabilizer with grounding as well.
Any advise or suggestion?:driver:
viostar
475
2
Hey guys,....
Some said modify it with the Denso FICD can solve the problem... is it true?
Anyone of you guys out there tested? Condition how? ok ka?
Once installed FICD, it bring any side effect on our car not?
Advise or suggestion pls!!
:itsme:
Thank you.
MITSUBISHI FTO STOLEN IN JOHOR BAHRU BLACK JEY 9911 - IF U C PLS CALL 012-7258618
If you spot a black FTO pls call owner 012-7258618. The car is completely stock and it has a university of massachusets rear window sticker.
