DIY-how to spray sport rim?
jegvd
1,932
hi, any idea how we can spary sport rim effectively and more reliable on our own?
what items are needed to do so......
kindly advice........
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
First of all, go get a can of paint striper. It is very acidic, be very careful. I do really mean that, VERY CAREFUL. I accidently drip water into the can unnotice and i close it up, it expands, i panic and open the cover, acid splash onto my face, luckily only drips. DAMN!
After striping old paint, get yourself new paint. If you have budget, get those spray car paints in cans from professional hardware shops and spray them carefully. Before that, sand surface with fine 320 sandpaper. :biggrin:
jegvd
1,932
where to get paint striper? and what is the name of the paint striper?
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
hardware shop sells them.
i sprayed mine using can spray only, but still perfect.. co chips..
striped, sandpaper, then 3 layer of colour, 2 layer of clear.
i use can spray brand samurai.
ken12292703
1,542
5,138
SoMeWhErE
Waaachaaaaa! Samurai!
It will be very very sharp, colourful and fast dry!
Same concept bro.
Maxx
2,072
42
5,148
PD-Putrajaya-KL
i think the samurai brand is the best spray than other brands.
the "spray" is smoother than others in my opinion..
if u can find acrylic clear will be better protection for the colour.
webeck948
55
Paint Striper (Paint Remover) is heLL acidic so please handle with great care!I accidentally spilt a few drops on my face and arms and it burnt like flame!But it did a charm to removing paints.
I brushed the paint removed onto the rims, inside and out to get a thorough strip-off, washed with detergent and rinsed off with water. Let dry under blistering hot sun before I evened off the surface will putty filler. Let dry again before water-sanding it with sand paper of 500 grit.
I started off with a couple layers of primer, I personally think the paint sticks on and lasts much longer on primer than raw metal, but that's just my own 2 cents, I'm not a pro hehe..
Let dry again, then apply the desired paint, and end it clear coating.
Mine turned out like a charm and it lasted and stayed on like a leech, all the way and went along with me sold car.
Happy DIYing!
lIMlIM
10
any idea where can get the car paints in cans from professional hardware shops in kl area :adore::adore:
opp61
259
5
Bud
Try SKL in SS2 PJ. Shop is same row and Mc D's. The boss face is kinda farked up but they do sell automotive spray paint.
Cheers!!
lIMlIM
10
Bud
Cheers!!
do you know approximately how much it cost for 1 can of spray paint ?
hiphoop11
24
erm.. i wan ask.. wat is paint striper?? issit tinner?? same thing or diff??
Maxx
2,072
42
5,148
PD-Putrajaya-KL
its an acidic liquid.
it will strip paint quickly.
use with brush to "sapu" and the paint strip off easily.
use with caution. its really acidic.
make sure got plenty of water nearby.
i read somewhere in zth that they recommend putting a bit of Tufoil into the tranny? what are the advantage of doing so?
i am currently using Redline ShockProof heavy with rating 75/240 cause i get loud "cluck" sound when engage gear using MT-90. with Shockproof heavy, the "cluck" noise if almost gone except a bit harder to engage gear during cold (start) which requires more strenght to push in gear.
