D.I.Y spray headlamp
xiaomao
281
Hallo all sifu here....can i know how to spray the headlamp kancil new circle one..??if have a pic more good....hope all sifu here will help...thans
deadman84
197
bike i done before la..use a sand paper to sand it to make it rough 1st so that the paint will stick on
xiaomao
281
ops...sorry i dint talk clearly mean spray inside the cover...not outside that cover...problem is how open that cover and how to install back the cover without problem...i know if no carefully do that become rain that water will into the lamp inside...so need all sifu help...
roadkill
106
To open the cover,u have to melt the glue thats holding it in place.Normally you pour boiling water on the edges to melt the glue,then pull the cover till it comes off.To install back, buy the hot glue gun and glue along the edges inside.Let it dry,then do the same alone the outside edge.U have to do this step very carefully or else your head lamp will fog up inside when it rains or when you wash your car!
Hope that helps..good luck
I haven't dismantled the front disc brakes before, so I'd just like to ask about this in case anyone's seen a mechanic do it.
The front disc brake has this "plate" behind the rotor, right? The plate's folded edges seem to cover a part of the rotor.
If I wanna change my front discs to 1.6's larger units (additional 1 inch to the overall diameter), it seems that there's not enough clearance between the rotor and this plate's folded edge. Can this plate be adjusted in any way to accomodate a...
