emanage tuning and installation
ganfh
462
Yuuuhooo....? Vteckiller busy ka? Our bro here needs some after sales service
vteckiller
Supporting Merchants
1,606
34
sorry been really busy this week..
how can i help u.
p/s to others yes we sell emanage and our price is rm950
tuning prices is now fixed at rm300 for all forum members for any tuning include ignition and fuel or injector.flat rate.new price to normal customers 350
so if u buy emange from us we can do package la.
emanage+ignition harness+install+dyno tune=RM1450
vteckiller
1,606
34
oh yah about the meter showing rich i think its okay la as the timers afr is not accurate la.
hmmm :) u must ask ksp to check back on that la.
core_pack
137
bro explain to me the differences between emanage and safc2 as it seems more interesting with emanage.you'd tuned my safc2(mivec) the other day and im thinking of taking it out as a replacement to emanage but i would like to know will it change a lot?
Chicken Little
121
vteckiller bro,i wanna ask how much u charge to install + tune fuel/air and ignition timing for a original kelisa 1.0,my car is a bolt on turbo,i bought my e-manage so i needed to know how much u charge me,thank you bro
vteckiller
1,606
34
the emanage is interesting coz it can do ignition timing..
its like safc with itc..
only thing both built in one called emange..
and seems hightech a bit coz can use laptop and tune ma..;)
think about it..
wont make much on your n/a mivec but should help a bit coz of the ign timing
vteckiller
1,606
34
bro,
tuning would cost u rm300 for ingnition and afr dyno tuning.
instalation usually rm100 to 120..
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Guys, I have wideband a/f and wondering if someone could guide me on how to tune E-manage blue. I'm running firmware 1.49 (Gold) on 4AGE 20V BT. Any help will be appreciated.
vteckiller
1,606
34
Tuning Tips :-
If your car is N/A try set your target afr at 12.5afr
so if u can get afr at 12.5 from maybe 3000rpm till 9000rpm and full throttle that should be safe and car should make good power.
you can run 14plus at idle and and light cruising.and at half or 3quater throttle target 13.3 or around there la but full throttle try run 12's ok.surely car wont bloW!
About turbo charged
same thing on cruise and etc...but on full boost and full throttle at 3000 rpm to whatever rpm must run in the 11's afr and u'll surely be safe...
surely no blow engines..
but on turbocars u dont add ignition on full throttle ok! leave it ori if original ecu is turbo ecu or u can retard more..
n/a can add bit here and there la..not to much but a bit la..if u are good and hearing at pinging..then u can put more or else carefull..too much will blow your engine! broken pistons...its call detanation! so beware!
cheers
Joshua
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Hey vteckiller, thanks for the tips. Really appreciate it. Is it true to stock BT will run too rich at full throttle? Mine goes below 12 AFR and goes down to 11 AFR when reaching 8000rpm.
Anyways, how much more power can a bone stock 20V Blacktop make with E-manage alone? +10hp?
Also, how much do you charge for dyno tuning including airflow, ignition, injector and acceleration map for E-manage?
vteckiller
1,606
34
yes usually stock always end real rich at the end.
ya if dyno tune properly should be able to get 10hp la if your car is really running very rich la.no probs.
bone stock usually about 100hp to 105hp at the wheels around there la
if tune well should get 120hp or so or close la.
approx figure..can always try before and after la.
i charge rm300 for dyno tuning emanage,ignition,etc...:)
cheers
Joshua
DJ-LanEvo3
960
Vteckiller, I went to ur shop today but I was not managed to see u..
anyhow, can I ask u to give me one tip plz?.. It's about E-management's
'Rotation Switch setting'. Once we took the cover out, there is
3 hidden buttons there from the left hand side. In Handbook (Manual) only
shows limited range of cars.... how do we set those Rotation Switches
for those other cars...? Such as Proton & Hyundai...?
For example, First Rotary switch is for Number of Cylinders. Then most
of cases will be 4 or 6 right? Am I correct?
pifecto14
348
Brother Vteckiller,I have PMed you my enquiries regarding e-manage, and am looking forward to get some feedback from you. As i am interested in installing e-manage. Thanks in advance.:adore:
desmd99
213
Tuning Tips :-
About turbo charged
cheers
Joshua
Hello joshua sifu, I am wondering if you do tuning on Stinger EMS standalone ECU for 1Jz-gte engine? It's plug and play system, how would you charge?
vteckiller
1,606
34
can can tune that but i dont have the software..so if u got your own software hooked up to your laptop..just drive by and i'll figure out how to use the software surely can tune la...
will cost u rm550 dyno tune la:)
desmd99
213
yes, the EMS standable ecu comes with software and a base map. Can tune for different map and keep the settings for future usage.
vteckiller
1,606
34
can no probs :)
shazmee
29
hello, want to know if tunning without wideband sensor but using afr meter will it be ok? normally afr will be under read or over read? thanks
vteckiller
1,606
34
depending in what afr meter la..
like inovate can la..
if u use those apexi pen timer afr or the cobolt auto meter afr die la..
if n/a maybe okay la..coz hard for car to blow if na but if turbo boost high sure blow la..coz not accurate coz its single wire narrow band la..
need to stick a 5wire or 4wire sensor on your tailpipe get the car tuned then only remove it..
try to buy innovate afr monitor la..
LM1 la..its cheap too..
check it out at Innovate Motorsports Wideband Air/Fuel Ratio Tuning
i also have stock for it la..
its rm1499 :)
kiran84
945
dunno
Hi Joshua,
i want to install an Emanage and dyno it from u real soon....
how do u check on pinging/detonation? do u use a ping box?
Mention the word Japanese muscle-car, and most folks will likely start thinking about the venerable Nissan GT-R. The GT-R definitely deserves plenty of praise – it is the only modern day Japanese offering that has been able to put continental supercars to shame is almost every department. Shame then, that Godzilla has cast such a huge shadow over Nissan’s...
