need some help from cifu!
kenneth 3331
117
my s15 is an autech version , in the future i wanted to bolt on a turbo.
it is suitable to do so ? and what turbo should be use ? and which work shop
is good on that job ? thank you :_:
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
autech version is na right kenneth?well,if i were u,i'll take the whole engine out n install s15 turbo version engine in it.just my 2cent.
kenneth 3331
117
em........... i think bf , now my car having 2++ hp .
so i think to add on turbo to try how many hp it will be ,
if i wanted to do so , what should i have to do ?
get a turbo , intercooler , oil cooler ...... etc .
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
ya lor kenneth,i've check already.ur car is powered by a sr20de engine.200ps,6 speed rwd.no need to up grade this engine lar.nowadays i think the half cut for s15 turbo is reasonable already.better u buy n install the turbo version rather then convert ur previous engine to turbo.there's a lot of work to be done if u really want to convert it.if u change to sr20det,u instantly gain 50ps more then ur original engine.just my opinion.:_:
kenneth 3331
117
thank you sir,
u are right 2, i still want to settle some of my car problem 1,
ah , do u know where to install e-manage is cheap and good?
powerfc_pro
61
bro,no point of doing bolt on turbo in yur SR20DE.coz the piston all thingys is for NA....some more is a high compresion engine,boost not high maybe 0.4+-....what for?staright away dump in a SR20DET.
as for ecu....diff ppl have diff thinking.if i were u...i will save up money n go for standalone.IE:power fc or if budget allow go higher range such as E11,Motec...just my 2 cents :)
4G93GTi-R
359
it suitable but only 0.5bar..coz of the piston n/a..turbo can pick from sr20det or rb20..
workshop dont know..coz you in kl...the cost we bolt on turbo for your tyep is rm1.7k to rm2.0k
if you hi cost..change low comperssion piston,metal gasket,exzos piping and engine management
spykey
681
kenneth? u the guy from x factory sunway meh?
spykey
681
ur rides bodykits blue black stripes rite?
my car last time chg to 4g93 gsr turbo engine...now im take out the turbo already . piston i already chg back to na piston...but manifold still using gsr turbo manifold...ecu chg back to normal na ecu.
my problem now is.. my car idle timing cannot stable..n vr hard to go over 3000rpm...(like injection spray too many fuel like tat) wat can i suppose to do right now.? chg ecu ? or add something like afc controller can fixed the problem.? the spark plug is black colour when i take out from...
