Short stroke? Long Stroke?? Shocks??
pillage2001
260
3,018
What's the difference between short stroke shocks and the normal length wan? I'm looking to pair it with my lowered springs on my SV4. :)
Any suggestions??
m3 power
924
7
lowered=short stroke, stock=normal stroke. the diff is the height of the shock. short is shorter n normal is standard height la. want to know more ask abs seller. hehe.
pillage2001
260
3,018
Like that also can ar..............
razr_sped
267
cos memang like tat mah...
u onli ask for de difference between de 2...ntg specific
pillage2001
260
3,018
Okie.
Let me reprhase it. What are the implications of Short and normal stroke Abs. Must lowered car use short stroke and only short stroke? If not, what are the advantages.
tk2005takeru
148
KK
Let take it this way,
Short-stroke absorbers = an absorber which travel shorter than O.E.M. specified height but will be a bit harder than stock absorbers to reduce the chances of dampers being "damped" together when going over bumpy roads, and I really mean "DAMPED".
Stock/Normal absorbers = an absorber which will travel as stated in O.E.M. specified height.
Stock Springs + Stock absorbers = Good
No comment on this.
Lowered Springs + Stock absorbers = Not that Bad
If you want your car to "damp" you more than you "damp" the car, feel free to try this settings.
Stock Springs + Short-stroke absorbers = Bad
This is a very good example of penis-elongation pill a.k.a. Viagra, only it is in absorber-term.
Lowered Springs + Short-stroke absorbers = Good if used and set correctly.
The car will be proud of his owner, unless the owner is a pothole-drive-thru-driver.
LuKa
618
19
Kedah
"Stock Springs + Short-stroke absorbers = Bad
This is a very good example of penis-elongation pill a.k.a. Viagra, only it is in absorber-term."
i have to disagree..
performance n ride wise will be a bit hard than stock,but still comfortable.. but ride height combo of short stroke shocks+lowered springs will not be convenient.. scraping n ground clearance of over speed breaker,bumps n potholes will occur
tk2005takeru
148
KK
But for gas-piston abs, it's elongation and not shorten, if the original spring is very bouncy, spring rate is high and stiff. Unless of course, Koni double actions abs, adjustable too. Can be pulled and pushed. =P
THE former rally driving champion Colin McRae was killed and his five year-old son feared dead in a helicopter crash yesterday afternoon. The aircraft came down in Jerviswood, Lanarkshire, half a mile from the family's home and burst into flames just after 4pm.
Jean-Eric Freudiger, McRae's agent, said the 39-year-old driver had been piloting the helicopter himself. Also on board were believed to be his son Johnny, another adult and...
