Perdana V6 Community Forum *
humongousgravy
189
Seremban
Yes I have to say trying out blindly because foreman seems unwilling to check further. He tried to swap the air flow sensor and water temp sensor but still to no avail. Actually after the transplant both ABS light and Check Engine Light was on.
actually I went to the halfcut shop and tried 0563 but the car was unable to start. Tried another 0456 and it started but with the same two error lights.
I bought the engine from another Perdana that was to be scrapped. My mistake was I didn’t start the engine. Am told the ECU came with the scrapped car.
30,002
In that case I think you should find someone who knows your type of engine.
First to scan to see what is wrong to be able to trouble shoot the problem....:smokin:
Reactions: humongousgravy
humongousgravy
189
Seremban
Yeah thanks bro. Sent the car to another mechanic to check. I also feel the car not that much different from my previous V6 NA. Used back the same 312 manual gearbox. Could it be related to the ECU too?
humongousgravy
189
Seremban
Tested with 6484 ECU, same check engine lights and ABS sensor. The new foreman did tell me the wiring harness seems to have been cut. There’s one open cable near the intake manifold . :Stupid:
30,002
Earlier I also wanted to ask about the wire harness, because even my mechanic who did my car transplant need to send to expert wireman to do the wiring.....
humongousgravy
189
Seremban
Now sending to a perdana expert. Hopefully can resolve this issue. Really feel the power is much less than I expected. Almost the same as before.
30,002
Just an update. Problem solved. Sent to another perdana expert. Changed a couple of items including the air intake. Now all is good. Thanks guys.
The air intake very very sensitive. I remember got one time I wanted to try open pod, so got the adapter, but one corner of the fit was like less than 1mm off. The car starts and run but once you want to accelerate it chokes. Remove fit back original no problem.....lol
humongousgravy
189
Seremban
I see. He changed a couple of items too. Looks like something called the Power TR in addition to the ECU. Also added quite a few air hoses to plug here and there, I’m guessing for reading/sensor.
Now looking to upgrade brakes and exhaust. Brakes if get VR4 or EVO won’t have to do custom bracket?
For exhaust size 2-1/4” enough? And what’s a good muffler to use if I want the sound to be just abit louder and bassy.
Reactions: minibeany
30,002
Your original brake is single pot? VR4 ones are double which was a improvement for me since my original was single and I transferred the servo also which was twin layer. Brake pads I am on Trestor Advantage pads.
My exhaust is 2.5" all the way until the muffler which is straight through. Some say can go up to 3", but better ask the pro exhaust guy.
Since you are fitting the muffler new, there is one now which you can switch the straight through on and off, meaning if don't want loud can off......lol
humongousgravy
189
Seremban
yeah now still stock single pot. If I changed the calibers and rotors will it cause the brake to feel more “mushy”? Or is that the reason to change the brake servo together?
Do you mean like a valvetronic exhaust? Would be nice to have haha
30,002
Brake servo aids vacuum so you get a stronger brake force. If changing to bigger rotor and larger calipers, best to increase the servo size too.
Yes, I think they call valvetronic exhaust....
minibeany
599
102
543
bassy sound u can try FGK S-flow.
humongousgravy
189
Seremban
Haven’t managed to solve the rough idle issue (sometimes goes to 1.5k RPM) but nowadays the car I can feel it’s choking. Like semput semput. And it still goes to 1.5k RPM on idle which makes the car choke less. Makes me feel that the problem is which the throttle body. Any advice?
30,002
Your idle speed is 1.5k all the time or sometimes only? If all the time can confirm is TB. I had this problem with my VR, mine even higher at almost 2K rpm. My mechanic confirm is the TB butterfly leaking. He dismantle, wash, tune whatever cannot solve, so I bought a second hand TB unit, now solved.... :driver:
humongousgravy
189
Seremban
Previously was sometimes only, and when not at 1.5K RPM it was ok engine idle wise and running wise. But recently when it's not 1.5k RPM the engine is like choking. and if it's at 1.5K it's abit better but still choking a little when driving. Still the throttle body?
30,002
In this case, Better get a mechanic to check it out, or probably try servicing it first.....
Hi everyone . I would like to know the price of gab hi low adjustable . Someone sell with rm750 . Is it real or fake?? Please help >.<
P/s : newbie here :)
