1jz E36 BMW frankensteining
sweelt
Nov 6, 2016
2,306
248
Are your rims a perfect fit to the hub? Did you install center cone?
Previously I had this problem also. The tyre shop boss where i do my balancing, he always centralized the rims for me. Later on he manage to measure and find me some center cones. Nowadays no problem at all with balancing vibration.
On wheel balancing is good, but problem is, every time you need to remove your wheels for any repairs, the balancing runs and need to re-balance. Now on Off wheel balancing, I have no problems at all.....
my tyreman machine plastic/teflon for center hub. so the wheels fit nicely.
ixeo
4,788
3,080
KL, Malaysia
I am using BMW original rims for E46, and no i didn't install any center cone. Some tyres like Falken Ziew 914 will never be balanced off wheel, it has to be done on wheel. This shitty Membat Passion tyres are good for grip but shitty in terms of comfort.
Thanks,
Ken
More than 10 years ago my friend's Falken Ziex 912 could never be balanced properly.
Mitevo7
1,456
179
Same here, the Falken Ziex 912 has to be balanced on wheel, cost me 90 bucks during that time in 2010, and the tyres are only good for the first 20,000 km's, after that it all nightmare and aquaplaning.
Thanks,
Ken
hero242
Sep 19, 2012
Hi all. Just following up here. Read from start till here. After all the issues and challenges u guys facing,
Is it still recommend to get E36 with 1jz now? :biggrin::biggrin:
Or should i look for the M50/M54 engine with manual gbox?
The japanese 1jz/2jz in a BMW is still a lot of fun and it's way more powerful than any stock BMW engine you can plug in. However it's just expensive and the lessons learnt are :
1. Find a good installer and tuner, someone who knows these kind of converts inside and out.
2. That installer needs to be super familiar with the JZ engine and it's quirks. Like removing the heater hose for cyl6 is ALWAYS a bad idea.
3. Expect this to cost minimally 20k excluding the engine and gearbox cost.
Or you can opt for the boring and more straightforward M50/M54 swap which potentially has the same requirements of #1 and #2 (Bmw engines are quirky)
Mitevo7
1,456
179
In my case, i don't have any trouble anymore after year 2019, all things are sorted out, i am currently running the JZ E46 with 260whp with automatic gearbox without any issues. If the borders are open after don't how many years, i am planning a long haul trip into Thailand to Bangkok with my E46 for the fun of it.
hero242
Sep 19, 2012
Wow thats cool.
Am now looking for a car to use for daily. Looking for e36 with 1jz or maybe e36 325i (M50).
Recently go see a 'parked' e36 but he is overhauling the jz and doing manual conversion together.
So not in a running condition yet.
Am a bit worried to jump into the hybrid Euro car from being a P1 and Toyota user for some time.
Mitevo7
1,456
179
Wow thats cool.
For myself, i would rather buy a untapped BMW E36/E46 with the right engine. You will never know whether the converted car is in the right order to use as daily ... For eg, one 1jz converted BMW E46 4dr i checked before, RPM is not working, water temp is not working, and speedo meter is not working. You wouldn't want that in your daily. It's literally a shitbox even with awesome JZ engine.
Reactions: hero242
hero242
Sep 19, 2012
Yeah was thinking the same.
Now in negitiation to get a good running E36 325 with M50B25 engine, and convert it to manual.
Mitevo7
1,456
179
Are you looking for a daily car or a project car ? There are plenty of good choices in the market for RWD car, for example, the Toyota Altezza is one of the most interesting car to own.
Reactions: hero242
hero242
Sep 19, 2012
Am looking for Daily and maybe some trackday action once in a blue moon.
Yeah i surveyed the altezza, but not cheap.. sooo i proceed with E36
Mitevo7
1,456
179
In terms of reliability, Altezza will be better and easier for 1JZ or 2JZ swap. E36, it's cheap to buy but for long term ownership, it's like married to a out of time supermodel wife that is very expensive to maintain with all the botox, plastics surgery, boob jobs and many more to come that will suck you dry. I am feeling it on my E46 now, in terms of the interior trims that i want to restore, dang they are not cheap.
  • Haha
Reactions: minibeany
yeah but when the supermodel works she works you'll be orgasming all the way to the track and all the jealous looks from other dudes with their plain jane wives.... i mean cars.... is epic.
If you're gonna daily her, e36 1jz/2jz will have one fundamental issue and that's a super hot engine. Air con will not work in a jam, things break faster cuz it's hotter, etc. You'll need to spend a lot on trying to reduce engine bay temps cuz the JZ brothers are hot chicks. Really hot chicks.
A friend of mine looking for workshop in J.B.
Any recommendation workshop for Subaru TS 1.6 to turbocharge?
He is looking for mod which can able to almost same 0-100 as WRX stock.
I think is impossible unless he also want to change 2.5L block.
So the workshop also must able to option for change block in case NO CHOICE. LOL
