Show us your lancer/evo pics!
Plan something big for dragday?
Anyway why meth inj...not ecu first?
No la, just normal drive only. I try avoid launching the car coz don't want to break the TC.
Coz meth kit is less than half the price of Link ECU, and can provide some safety margin for tuning. My tuner also said the stock ECU is still sufficient for my target now. He'd recommend Link as next step. Main differences if not mistaken are it has antilag setup, and multiple maps to select for say different fuel types etc., plus broader mapping capability. He's selling his Evo 9 so now in process of demodding it back to stock. I may consider buying his used Link later for half the price.
Link makes a PNP ecu for the Evo. No messy wires and all that.
Also 376 on a mustang dyno is GOOOOOOOOOOOOOD... that's pretty high HP! Hope your brakes are up to par
Reactions: 6UE5t
Yup Link is PnP, most recommended for Evo.
Considering the limited amount of mod and spending I put on it plus a bit more conservative tuning, yes it's pretty good already hence I am satisfied. Probably if pushed a bit more aggressive with 50/50 meth ratio and 1.7 bar should be able to cross the 400whp mark.
Brakes use stock calipers still ok. Mine got uprated floating disc with slots, some Endless pads, stainless braided hose, and use Motul 5.1 fluid. Later once pads finished, I might consider higher performance pads.
Daily drive you need so much power ah......
Surely no! Hahaha. I just set it at low boost for daily, maybe around 1-1.2 bars.
This results actually exceed my target. Initially I was just targeting around 320-340whp, then plan my mod or things to buy based on that with some budget level. More or less I am spending about that budget level with pretty careful parts selection and hunting, then got this higher result so yeah, a nice bonus I suppose.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
View attachment 578117 View attachment 578118 View attachment 578119
Installed AEM water methanol kit, then went for dyno tuning at LSF Sunway with Matt Dirin and Akong. Got 376whp/410wnm @1.4 bars on the Mustang (est. 470hp/530nm on crank). Methanol fluid ratio is only about 33%. Not too aggressive tuning but pretty pleased coz target exceeded so stop power mod for now. Maybe would only consider Link ECU if got a good deal somewhere.
Downsize rims to 17x9 Konig Hypergram, lighter by 2kg/corner, plus got some AD08R. Previous 18' got buyer already.
Next plan just do corner weighing and change android head unit.
looking good, very nice example you have there
Interesting meth kit route for initial mods but agree with your thoughts
I had a meth kit once, it does add meat to the boost
Reactions: 6UE5t
Hmm can't remember if I had mentioned before but earlier this year I had changed to Greddy 264 cams, HKS GT2 7460R ball bearing turbo with 18psi actuator, 850cc injectors and Walbro 255 pump. This meth kit is the last addition.
He needs to climb a lot of bukit and slopes in his daily drive... hahaha... like office parking ramp... LoL...
BTW, back to office?
Hahaha now office parking very empty, no need to go up/down.
Anyway still WFH, so cars not used much now.
The Marketplace Top Posts
my friend driving kancil 850... he forgot to put back the radiator cap after he check before his journey..
for some distance the temperature go high and after he check back, the water in the tank already dry... then he top up the water into the radiator and after that, his car broke down and cannot start back...
what is the real problem hear and what should he do??
getting help from expert.. :)
p/s: sorry for grammatical mistake
