KHNG940413
668
56
johor bahru
eh... you are not supposed to be able to shake the sensor bracket and all la wahlau... anyway it's beginning to sound more and more like sensor problem
I am not shaking the bracket sensor lah,hahahaha
I juz hold the sensor top wire tarik abit & goyang abit see will it make the engine dead.
Juz now I go to spare part shop and ask for Original Proton crank sensor is around RM190.
Haven't bought it yet since my car now still running ok....for now....hahahahahah
You skimped for 190 bucks? Man oh man - chinese sensors are never good. Even those aftermarket meters using chinese sensors are rubbish.
Reactions: sanekit
KHNG940413
668
56
johor bahru
No lah, tomorrow only go and buy. Juz pass by and ask them 1st. Will update after installing the original
Sensor
sanekit
Dec 9, 2015
1,616
157
Sensor
maybe it it caused by the china OEM sensor. haha. coz if i remember correctly, VDO is a bit choosy with sensors.
and as @Izso and @parakey mentioned, the sensor supposed to be tight and snug at it's bracket/holder. it's not supposed to move even if u try moving it with your hands.
minibeany
598
102
543
yeah... kena before... put in a OEM sensor... problem persist... When changed to original sensor problem solved
Reactions: sanekit
Just reacently changed my Yrv turbine to Garret AR48, and there are powerloss because of insufficient fuel going to the engine. which is better, i was told that if i used fuel injectors i can tune it with my e-manage, and if i was to change fuel injector, what injector should i change to?
Fuel Regulator can make the fuel more rich to the engine? :confused:
