parakey
1,367
226
aiya~I not pandai to see the caliper to be honest with you. SO i need to use google to hlp me convert.Hahahahaha
From the photo you shared earlier, the reading on top are Empirical while the bottom one is Metric.
Each small line on that scale is 1/16 of an inch. The next line is longer and denotes 1/8.
Starting from the 1" mark, you count the lines and arrive at 1 12/16 which simplifies to 1 3/4 which is 1.75 inch
KHNG940413
668
56
johor bahru
So I assume is a stock exhaust pipe I guess?
Super stock. Time to upgrade. Hehehehe... if you change extractor get a tuned length 4-2-1 and then 2" your piping, add a middle resonator (straight flow tabung type, not those stupid swirl bullets) to reduce the drone and add a straight flow rear muffler. The bigger the better for a nicer tone and less noise.
KHNG940413
668
56
johor bahru
Sound very poisoning.....Hahahahaha.
I juz saw a 4-2-1 extractor stainless steel one.
something like this
Is it ok I use it and sambung back my ori pipe or juz do a set of new exhaust is better?
Even straight through rear muffler, after a while the fiber glass disappears the sound will change. Mine changed completely, but then mine close to 20 years already......lol
leinnz
333
57
3,028
KHNG940413
668
56
johor bahru
To me I want a deep tone sound. Not those prangggggggggggggg when you tekan minyak and this is what my car sound now.Even when you up shift your gear it will have the pop sound. I think I am at the age I feel pranggg sound is to annoy to me.Hahahahaha
Mine very deep bass sound. If alarm with motion sensor, even if I drive pass slowly the alarm will go off......hahahha
Reactions: KHNG940413
leinnz
333
57
3,028
Which mean I need to do a new set piping if I use this extractor?
yea. if use existing maybe ada power loss. a proper set may be better. IMHO. i am still learning
something like this
You can - not to say you can't. But I've never used this brand before so I don't know how it affects performance. It looks like a Jasma brand extractor.
Compare that Jasma with this :
This is the Powerzone one. The way the collectors merge is different. Powerzone is a more reputable brand but if you got budget have a look at Supercircuit exhausts as well. They can do the whole exhaust. There's a few brands out there - you need to get opinions from people who have used them.
My old car had the whole exhaust done by Everco way before they were expensive. I had the front to back done for 1300 back then (close to 20 years ago).
As the title suggest, I need some information from actual users of upper pillowball mounts. What improvements I will be looking at if I change my stock rubber upper mounts to pillowball type? As far as I know the accuracy of the geometry will increase. How is the ease of adjustment? and when I do adjustment do I need to jack the car up or just do with the car tires on the ground. If use on daily driven car, if there any potential problems that could arises? Is adjustment on the pillowball...
