Ever tried a simple DIY then causing a major F**K UP! .... Share you stories
sweelt
Nov 6, 2016
2,306
248
If i recall correctly, its not about the voltage ( V ), its the current ( A ) that hurts us.
For example, car battery is only 12V but there are variation of capacity. I did mention that i dropped a wrench and it made + to - connection on the Pajero battery....that split second contact left a permanent mark on the terminal and manage to warm up the wrench. Imagin the energy that is stored in the battery.
Another proof is that i have seen video where offroader hook up 2 unit of 12V battery and uses it to weld.
3 phase 440v but low amp wont do much damage to human. Will feel the zap lah.
Engineering manager told us very lucky becos few of us kena zap by voltage leak into electrical panel.
You like to feel zap and won't get killed, try the car plug wire......lol
Is 3 phase lower amp? I know house 240v can kill.......
Ok, just read on it, the higher the voltage, the lower the need of current to flow.....
I seriously doubt that's a good idea. That zap is plenty enough to stop your heart man. Siao
Sounds like the number of DIYs we've screwed up is quite a lot. I screwed up a Ikea door once and terbalik installed it. I went back to change the door and installed the door the wrong way again. Damn cibai. I need better glasses.
Nope, what u need is common sense...hahahah.
ixeo
4,788
3,080
KL, Malaysia
Long time back, DIY tire rotation on my Mitsu Eterna, resulting in cracking one hex nut, hence could not open! This was probably due to the tire shop tightening it too hard previously, and maybe my tools not up to std too. Ended up went to a machining shop, welded the hex key to the nut then open, but rims got burnt/melted paint in some areas near the center.
Another one just happened a few months ago on my Evo. Tried to switch battery while engine on. The positive terminals doesn't have the rubber cover and accidentally touched the strut bars hence engine shut. Forgot to take the keys out, windows was closed, then hooked up the battery and the the doors all locked! And I didn't have spare key yet! So yeah, had to pay locksmith to open up the door. Just stupid mistake.
The first thing all the workshops I go to do is...lower down driver side window...It's like a SOP.
Reactions: vr2turbo
ixeo
4,788
3,080
KL, Malaysia
It’s easy to get to the top but staying there is another question altogether and Nissan probably knows this all too well. They haven’t relented on fine-tuning and upgrading their GT-R year after year in an effort to keep it on the heels of supercars.
But just like every other great thing, it too must come to an end and the five year model cycle for the GT-R will enter its final year in 2012 and the...
