Like that the copy not actual copy because different.........hhahahhahaha+35 offset is already plenty out....
u sure the wheel is ori rpf1?
i suspect it was some shit replica copy fake imitation
Yeah, I also suspect it's a bad replica of RPF1. RPF1 is a very popular wheel for JDM performance cars which almost by default use big multipot calipers, so hearing RPF1 cannot clear stock and small Vios calipersis very surprising. Here as proof, the Toyota Gazoo Vios racing cars are using RPF1 too!+35 offset is already plenty out....
The offset of ori rim i dont knowvios has tiny calipers, rfp1's also have very flat spokes that dont curve in and the original rim offset is 45 kan?
dont see why it should hit the caliper....
eh cannot main change change like that without knowing the diferences between the rims you have and the rims you want to change toThe offset of ori rim i dont know
No block ,just touch amd abit friction when rotate the wheel,my foreman friend also suggest to grind the caliber,will it affect anything?Hmm rather strange, that means the caliper also barely clears the stock 15' rims, is it? If the touching is just very slightly grazing the wheel barrel then you can consider just grinding/sanding just some small section of the caliper surface where it touches. If it touches too much until the wheel really got blocked by the caliper then no choice but to use other rims.
The rim is ori rpf1 bro+35 offset is already plenty out....
Rm2800 for the rim,mine is 15inch.If u don mind, how much u bought rpf1 ?
I think sanding it a bit should be ok then.No block ,just touch amd abit friction when rotate the wheel,my foreman friend also suggest to grind the caliber,will it affect anything?
So you bought them new then, damn expensive!Rm2800 for the rim,mine is 15inch.
The gazoo racing vios who know what offset is it for the rpf1?for 15inch rpf1 got 3 different offset.28,35,41
OEM rims offset normally further in, like 45 to 55The offset of ori rim i dont know
