Rpf1 ori 15inch offset 35 cannot fit in vios xp150,anyone can help?
+35 offset is already plenty out....
u sure the wheel is ori rpf1?
i suspect it was some shit replica copy fake imitation
Yeah, I also suspect it's a bad replica of RPF1. RPF1 is a very popular wheel for JDM performance cars which almost by default use big multipot calipers, so hearing RPF1 cannot clear stock and small Vios calipersis very surprising. Here as proof, the Toyota Gazoo Vios racing cars are using RPF1 too!
http://www.zerotohundred.com/2017/r...car-first-drive-toyota-gazoo-racing-malaysia/
Reactions: vr2turbo
jeffryfei
15
vios has tiny calipers, rfp1's also have very flat spokes that dont curve in and the original rim offset is 45 kan?
dont see why it should hit the caliper....
The offset of ori rim i dont know
jeffryfei
15
Hmm rather strange, that means the caliper also barely clears the stock 15' rims, is it? If the touching is just very slightly grazing the wheel barrel then you can consider just grinding/sanding just some small section of the caliper surface where it touches. If it touches too much until the wheel really got blocked by the caliper then no choice but to use other rims.
No block ,just touch amd abit friction when rotate the wheel,my foreman friend also suggest to grind the caliber,will it affect anything?
lsm1991
1,469
185
if its a tiny bit, well u can do that OR you know... just get a very thin spacer
jeffryfei
15
If u don mind, how much u bought rpf1 ?
Rm2800 for the rim,mine is 15inch.
The gazoo racing vios who know what offset is it for the rpf1?for 15inch rpf1 got 3 different offset.28,35,41
I think sanding it a bit should be ok then.
So you bought them new then, damn expensive! :biggrin:
Don't know, Tom should know better coz he had raced in them.
so u got the 7jj +35 offset right? thats the max u can go...
another is 7jj +41 will make the caliper stuck more than the wheel u got now....
if 8jj +28 also most likely u will face similar scrubbing with 7jj +35
i would say instead of grinding the caliper... just add 1 think spacer like 5-7mm spacer...enough already to clear the caliper
mADmAN
1,840
547
why laaaa u guys keep talking about offset... he already said its not touching the spoke... its touching the barrel. changing the offset wont help.
imagine taking a 15" wheel.... and trying to fit it to a ferrari brake disc and caliper...no matter what the offset is it wont fit in the wheel coz of the barrel size right? abit extreme example... but same thing lor.
TS either has to change wheels... or if the mechanic can do it safely, grind down the caliper abit for clearance. or installing a slightly smaller brake system. id recommend changing wheel.
Reactions: jeffryfei
i m driving a wira a/b 1.5 auto year 2001...
wat i found out is the car really eat alot of petrol (for me)... last time when the petrol price still (rm1.62) ... i can only manage to go 250KM for RM50
worse...when nowdays (RM1.92) RM50 can onli go for 200KM....
izizt something wrong with the car?? i normally maintain the rpm below 3..city driving only..pls help...
