[DIY] Oil catch tank
Kevinho
94
Puchong
My understanding is there shouldn't be a vacuum. But for some reason my crushed. Could be engine heat also but that's unlikely
I saw some post saying that you made the cylinder bore bigger right ?
Could it be that ?
Bigger volume in the combustion chamber.
Suck more air in during downward stroke. Causing morem vacuum than usual at the breather hose side.
Not sure whether it works that way.
Could it be that ?
on my Myvi? It's completely stock. My old wira is a different story
I dunno.. maybe I connected mine wrongly or the filter was directional and I fitted it wrongly
Even terbalik, won't get crushed. Maybe because of heat it melted but then in my turbo VR also very hot still survived.......lol
Kevinho
94
Puchong
I'm gonna try on my brothers Myvi to see whether got strong vacuum like u said.
Oh ya, guys, if I placed my oil catch can here shouldn't be a problem right ?
Away from engine, between battery, air box and fuse box
noripsni
Jul 3, 2018
32
19
64
your crankcase runs at positive pressure, not a vacuum, its why you can blow crankshaft seals if the breather is blocked, the reason is some compression escapes past the rings, on the fiat engines at high rpm (7-8k rpm) the pressure is such that it can stop the oil draining back from the valve cover, causing filling of the valve cover, oil starvation to the cam and lowering the oil level in the sump, so abarth had a crankcase breather with oil arrester AND a valve cover breather with pipes going above the engine, then down to a catch tank. Now I know your car is not a fiat abarth, but i use this it illustrate how all internal combustion engines run at positive crankcase pressure not negative (vacuum), My plastic oil tank is also shrunken on my Coupe, its due to exhaust heat and the hot oil fumes melting the plastic, these bottles shrink when heated, try it, throw a water bottle on a fire.
Heat from oil fumes shrunk my plastic petrol filter OCT. Makes sense but I didn't think a K3VE would make that much heat.
My VR runs even hotter if not mistaken, but plastic catch tank still ok.....lol
The parent company of Subaru, Fuji Heavy Industries, has just announced that it has penned a memorandum of understanding with the Tan Chong Group to locally assemble an unnamed compact SUV from its line-up.
Although the only SUV available in the Subaru line-up currently is the Forester, the vehicle in question could be the Impreza-based crossover that was previewed by the XV concept at the Shanghai Auto...
