Myvi Spring Crack
The rubber ones will have bearings too, right? If not, how does it turn?
the problem is the rubber loosens or breaks and the absorber top is sticking out into the engine bay. Alza one is completely metal on the top so it won't break perhaps?
Ah! that one my VR same issue. The rubber for some absorption but like yours they don't last. Mine will start to crack then when gets worse, need to change dy..... :bawling:
ixeo
4,788
3,080
KL, Malaysia
Use the Alza ones, its slightly better and you need a washer to adapt it to Myvi. Try and get the original Perodua parts instead.
RENESIS VIII
7,063
950
Ipoh
Bought the car to mechanic for maintenance today. Took a look at the springs myself and took this photo.
From this photo here, can tell it is not the spring but the rubber cover
i currently using 75A Mf bat..now the indicator show black color which mean recharge...so how i gonna recharge it? as i know those bat shop only can use their elec equip to charge up until 60A only...so how to recharge it?
