Fire order 4G93 DOHC
Bremboy71
15
1,503
Anyone have a diagram of fire order for a 4G93 DOHC non Turbo? From Coil module to plugs.
Thank you.
if not mistaken there is number stamped at the coil output nearby the spark plug cable....
Usually should be 1-3-4-2 right?
firing order is usually 1-3-4-2 but probably the thread starter confused after removing all spark plug cable and scratching heads to reinstall correct cable position and length :hmmmm:
I used to label them before removing, but my cars now all different length so won't mix. With technology nowadays I just take picture with H/P then start to remove.....lol:rofl:
hello friends and sifus.....i just do some minor modification on my satria neo...currently im installing 1 inch spacer into my wheels....so the problems is how can i diy to flip the arc fender myself....i have browsing the u tube and see how to do rear fender rolls....it required some machinery to do it...:wavey:
