Fire order 4G93 DOHC
Bremboy71
15
1,503
Anyone have a diagram of fire order for a 4G93 DOHC non Turbo? From Coil module to plugs.
Thank you.
if not mistaken there is number stamped at the coil output nearby the spark plug cable....
Usually should be 1-3-4-2 right?
firing order is usually 1-3-4-2 but probably the thread starter confused after removing all spark plug cable and scratching heads to reinstall correct cable position and length :hmmmm:
I used to label them before removing, but my cars now all different length so won't mix. With technology nowadays I just take picture with H/P then start to remove.....lol:rofl:
The next M3 looks set to arrive soon and is expected to push over 500hp. In this video released by BMW hours ago, they’ve confirmed the new M car will be offered in both rear wheel drive and 4 wheel drive, which is an Interesting proposition indeed.
Just barely noticeable from the video, the rear of the M3 prototype seem to swell through the camo clearly hinting at a wider body. Not forgetting the visible new air intakes, bigger wheels and mean stance...
