you change original? how bout the cost?I use original fuel pump only.......
don't believe him..you change original? how bout the cost?
wow..ron100? damn rich MAN..hahahadon't believe him..
you look at his nick, an original fuel pump will be suffice for his needs?
he only runs rich, ron100..
Bro., all stock, so no need upgrade pump lah! In fact, at the beginning I had problem with the pump. It stops pumping at time, so my mechanic thought pump konk, so he find used one. Fit it time it runs, but off and on it stops. Finally found an ECU guy he say your pump no problem, your ECU failing. Not long later the ECU really konk, then change ECU. The pump still the same one for 15 years dy.don't believe him..
My mechanic bought used one, but still using old one. Bought one still keeping as spare in tool box, not sure after so many years can still use or not.....lolyou change original? how bout the cost?
oic...My mechanic bought used one, but still using old one. Bought one still keeping as spare in tool box, not sure after so many years can still use or not.....lol
Ron100 no difference to your car meh? I thought you can boost more aggressively with that.Bro., all stock, so no need upgrade pump lah! In fact, at the beginning I had problem with the pump. It stops pumping at time, so my mechanic thought pump konk, so he find used one. Fit it time it runs, but off and on it stops. Finally found an ECU guy he say your pump no problem, your ECU failing. Not long later the ECU really konk, then change ECU. The pump still the same one for 15 years dy.
I did try one tank Ron100, like no difference, so back to 95, not even 97.....hhahhahahah
As mentioned all stock, still at 0.6 stock boost. Car is old, certain parts may not stand up to higher boost.......lolRon100 no difference to your car meh? I thought you can boost more aggressively with that.
haha...at one glance thought I saw Ipman....now your car got wing chun power dy......lolyesterday i change the fuel pump. Epman brand. cost RM265
Haha yeah, if use same boost then no additional power lor, then just use the same ron 95. Unless you remap maybe can make it a bit leaner and therefore slightly better FC, but still risky.As mentioned all stock, still at 0.6 stock boost. Car is old, certain parts may not stand up to higher boost.......lol
Even boost higher, seems according to mechanic original pump still enough because pressure high enough to supply......Haha yeah, if use same boost then no additional power lor, then just use the same ron 95. Unless you remap maybe can make it a bit leaner and therefore slightly better FC, but still risky.
